SOURCE: what is a .sdf file? How to generate a .sdf file using ms access?
Regarding what is .SDF -- A file format that is compliant with the combination of SQL Server 2005 Compact Edition, SQL Server 2005 and
Visual Studio 2005 to build, test, deploy, and manage applications for
users. Databases of this type can be accessed directly as a datasource,
e.g., from Visual Studio 2005, or from SQL Server Management Studio. As
such, they can be passed around with programs or projects, although
they are mainly used for embedded applications. The file includes all
necessary code points to access the data, and so does not require an
instance of SQL Server to be installed.
You can create a .SDF file with a software called PocketSYNC. (Although i have never tried it myself, a lot of people claim that this software works like charm. But it is not free)
SOURCE: Problem while loading the xls file
hello my friend, the error refers to the writing of xls to xml of the file. So therefore the error committed within the software side particularly in the excel software. Try to convert another xls file to xml files then if you find same problem i advice you to used full version of office rather than using light version. Then reinstall the office particularly the excel software
SOURCE: convert xls file to xml file in office 2007
I have not worked with XML at all, but you say you have Office 2007. I just created a spreadsheet in Excel 2007 and then I saved it by File>SaveAs>XML Spreadsheet. Have you tried that?
SOURCE: What is a .sdf file? How to generate a .sdf file
http://filext.com/file-extension/SDF , you will find here info about a .sdf, it has more meanings
Consider exporting day-book.Go to day book press export button or use shot cut key Alt+E. Exporting screen will displayed.
Press Back space on your keyboard. And
select Format as ASCII (comma delimited). Now give output File Name as
Daybook.csv, now select some other option you want to export from the
bottom of the screen.
Press enter to accept screen. Day book is exported in to tally program folder. Check program folder for file daybook.csv,
Double click on it, the file will open
in excel program. If you want it in excel work sheet file, use the
option Saveas, and save it in Microsoft excel workbook (*.xls) format.
Hope this is helpful. Let us know if the issue is resolved.
*Rating and Comments are invited for this solution
