All other features of unit work fine. Music and photos play ok. Power light shows green full charge etc
SOURCE: acer laptop power problem
Does not switch on from mains.?????????????
PLEASE EXPLAIN..........
Is the laptop lights not coming on when you plug it in? If not refer to the following.
Are you sure that your power plug has not broken loose. You will have to take the laptop apart to find this out. Sometimes the solder joint will come loose. Do not take this laptop apart unless you know what you are doing. The manual can give you step by step directions sometimes. It is not easy to take it apart without breaking the little things. If you do take it apart, take pictures of every step and take notes and even draw picture so you will know where everything goes. You can touch the plug where it is soldered and re-solder the plug. Please be careful. This takes someone with good solder skills to do.
SOURCE: My Acer Aspire 3680 will not power up.
Try leaving the battery out overnight. Sometimes it takes a while for the internal electronics to go 100% dead. Also, try holding down the power button for 10 seconds; that occasionally helps. Alas, it looks like you have a hardware failure, so the above may not work. Is your data backed up? If not, the drive is easy to remove and aspire 3680s are cheap on eBay.
-Guy Macon
www.guymacon.com
SOURCE: Acer Aspire won't power on with fully charged 9 cell battery!
Acer Aspire One BIOS Recovery
The AA1 has a built-in BIOS recovery routine, making it possible to
flash the BIOS even if the system doesn't boot anymore. It's only meant
for emergencies and may void your warranty, so use at your own risk.
Follow every step carefully!
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected.
Press Fn+Esc, keep it pressed and press the power button to turn the
AA1 on. Release Fn+Esc after a few seconds, the power button will be
blinking. Press the power button once. The AA1 will now initiate the
BIOS flash, do not interrupt it under any circumstances. After a while
the power button will stop blinking, and the AA1 will reboot shortly
after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it
doesn't reboot by itself wait 5 minutes before turning it off, just to
be safe that it isn't still flashing the BIOS.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
SOURCE: acer aspire battery won't charge
There is a battery cycle reset in BIOS. try that first. If not see if you still have manufacturer warranty to get a new battery.
SOURCE: Total battery power remaining: Unknown
Well you can try a system restore.
1.) start
2.) programs / accessories / system tools
3.) system restore
follow the on screen instructions too restore the computer to a few days before it started having problems.
Chances are that the battery is shot if system restore fails.
