Black screen
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
SOURCE: Emerson LCD TV/DVD combination turns
The problem you have mentioned is called OVP(Over voltage) fault. This type of fault is usually associated with the power supply board or main audio video board. There are several components that can cause this problem, but most commonly faulty resistors, voltage regulator and capacitors. These components have to be tested to determine the source of the fault and a component level repair has to be performed/ the board needs to be swapped. Would you like to do it yourself?
SOURCE: THIN BLACK LINE IN PANASONIC PLASMA SCREEN
If it is a cable...There are many(from 7-11)driver ribbon cable with horizontal driver chips mounted on them!!!! So if problem didn´t go away after fixing all cables...your plasma has died.
SOURCE: my lcd tv keep flashing the on botton when i turn
The power supply needs repaired NOW. I suggest you do not play it---unplug it ---and take it in for service. If you continue to play it you will price yourself into a new tv.
SOURCE: SEIKI TV Won't power up
The main power supply regulator board to your TV should be troubleshooted. In most cases, it might need card base replacement.
Testimonial: "I was looking at a picture of the board and noticed it has a fuse box. Could it be that simple? here is a picture of the power supply board. http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=200926504694&item=200926504694&vectorid=229466#ht_715wt_1044"
