Gateway MX6424 Notebook Logo
Posted on Nov 19, 2007
Pls helpme ask some help there of why my gateway mx6424 with processor amd turion 64 was no have sound. ill format it because ill reinstall the OS and of course the driver of audio controller is reinstalled but after reinstalling still have no sound... ill already try to reinstall the conexant and realtic ac 97 but still have error or installation failure,,,,pls hel me
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Nov 19, 2007
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
Helped
3755
Points
6
Hi
again reload your os with full driver then checkif same poblemthen connect a sound card with driver it will help full to you.
by by.
1helpful
What is the best processor to get for upgrade?
Here is the Fastest processor that will physically fit Turion 64 X2 TL-68, but this will use more power and generate a lot more heat. The best I would advise is the Turion 64 X2 TL-60 This draws the same power and will increase the speed to 2Ghz on 2 cores. So the extra heat produced should be minimal and your battery life should be very similar.
1helpful
Will a turion 64x2 processor from a av7170 interchange with a sempron processor in a 7115-eh1?
Processor Type 754-pin (uPGA); 638-pin (uPGA)*
Support Processor
AMD Turion64 X2 Dual Core
Processor,
AMD Turion64 Processor
(25/35W series),
Mobile AMD
Sempron™ (25W series)
Those are the ones that your laptop supports
Laptop shuts down on its own constantly. Have had for two years but only used for about a year because of problems. Gateway M series AMD Turion processor 64 2 gb 2 mg 32 bit operating
If heatsink is very hot then apply thermal grease between the processor and the heatsink or you can test if it's cooling problem by cooling with an external, powerful cooler.
1helpful
Which is better processor between amd athelon ,sempron, turion 64
Hello rakeshmedita,
The Turion is more of a mobile processor meant for laptops since it uses less power while the athlon is for desktops and uses a bit more power. The Turion might edge out the Athlon on performance but will beat the pants off it in power consumption. The sempron is a low-cost processor meant for entry level desktops. So, to answer your question it goes Turion, Athlon, Sempron.
Hope this helps, if so please leave some positive feedback. Thanks.
Acer amd turion 5102
reinstall the driver and try again.
1helpful
Amd turion serial ata drivers
Go here:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-41728-1&lc=en&dlc=en&cc=us&product=3263216&os=228&lang=en
Download and run the file and it will extract the contents into C:\swsetup\SP33031. Inside there will be an IDE\WinXP folder. Those would be the drivers you'd want to slip into your new disk.
2answers
Can i upgrade my processor from 1.9ghz to 2.8ghz?
According to Acer's website sepcifications, that Laptop is only upgradeable to 2.3GHz:
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=606&formid=3404&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
AMD Turion 64 X2 dual-core mobile technology TL-66/TL-64/TL-60/TL-58/TL-56 TL-52 (2x 512 MB L2 cache, 2.30/2.20/2/1.90/1.80/1.60 GHz, 1600 MHz HyperTransport Bus),
AMD Turion 64 mobile technology MK-36/MK-38 (512 KB L2 cache, 2/2.20 GHz,), supporting AMD PowerNow! technology and AMD HyperTransport technology or
AMD Athlon 64 X2 dual-core mobile technology TK-53/TK-55 (2x 256 KB L2 cache, 1.70/1.80 GHz), supporting AMD PowerNow! technology and AMD HyperTransport technology
2answers
Problem with Turion Ml-40
You can buy the same processor and it costs around $165.  Check this link: http://www.dealtime.com/xPO-AMD-AMD-TURION-64-MOBILE-ML-40-2-2GHZ-35W-L1-128KB-L2-1MB
And for the second part of the question, i did not really understood whats the problem.Can you be more clear... Can u give me the error message,the OS you use and which program makes it to freeze?
Generally this freezing happens when the processor is getting overheated.You may have to change the thermal coolant paste applies to the processor.Check out with your nearest hardware expert.
Amd turion x2 rm70 vs intel core 2 duo t5750!!!!
I read this and don't believe you - yes the AMD dual core gets hot - yes AMD processor are HOT processors - is intel better - no there on par with AMD - the thu put rate is so close it doesn't matter - now vista basic is just that BASIC - if you want to bump it up - home premium 32 or 64 but ultimate 64 should get it going.
2answers
Dear sir
you have installed the wrong driver... AC '97 2.3 Compliant Audio found on the CD that comes with the laptop
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
