We set the clock to required time but sometimes it makes tea others it will not work.
SOURCE: GE Spacesaver Microwave Oven JVM1640BB
unplug the unit and if you can open the housing and slowly remove the ribbon cable of the touchpad console to the main board. put it back after 5 minutes and try it. let me know what happen.
SOURCE: Swan SM2050 microwave - everything works (light,
you not going to like me now!!!! in two words,,,,,dump it,,,, your microwave is well past its best,,to fix it will cost more than its worth, and to be honest there getting cheaper by the day now?
SOURCE: I need a manual for
Most major manufacturers supply manuals
online so if you were to log on to the manufacturer's web site, you
may be pleasantly surprised as usually, if available, one is able to
download, by model number, Customer
Instruction Manuals, Dealer
Network for spare part supplies as
required. The information is normally free of
charge. I hope this helps.
SOURCE: Got swan sm2060R microwave. Plugged it in clock is set but no functions working
test the power outlet plug some lamp desk if work is o.k if NOT reset the c. breaker. follow this stepFirst check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
God bless you
