Check this out
Where to Find Your Model Number
SOURCE: NETGEAR WGR614v7 Network Security key
Hi, you need to connect to the routers admin pages to configure the wireless settings and security. Check out this page:-
http://kbserver.netgear.com/kb_web_files/n101676.asp
When you get to step 6, click the WPA-PSK security setting and it will give you a box to type in a password of your choice, make it memorable but difficult to guess, so a mixture of numbers and letters. I think its a min of 8 characters.
Hope this helps..
SOURCE: wireless secured network key code
Hi BabyDoll - to find your key, log in to your router. Enter 192.168.0.1 into your browser. If the defaults haven't been changed, the user is " admin" all small case without the quotes. There is no password. Just enter the user and leave the password blank. To get the key, click on the wireless button on the left. Then look down the page and you'll see the passcode fields. This is what you're looking for. Also take notice of what's above it such as WPA, WEP, etc. Write this info down. You can also go into your pcs that you use wireless on and put that key in and the kind of security (WPA, etc) so that it will not ask for it every time.
If this solves your problem PLEASE rate this as fixed. If not, DON'T RATE YET. Let me know what happened and I'll be happy to assist you further. If you need to know how to enter the info so that you won't have to enter it all the time let me know. I'll help you with that. Let me know what happens. Thanks.
Jeff
SOURCE: unsecured network shows up as secure
The person who has the router attached to there computer must enter the IP for the router and you will be able to reset the password to enter the router. If you need Help doing this I can solve this issue with you through my computer.
Hope This Helps
All The Best,
RCF
SOURCE: trouble connecting on my netgear router model wgr614v7
Posted a solution on your other thread:-
http://www.fixya.com/support/t1594223-netgear_wgr614v7_network_security_key
SOURCE: Router (WGR614v6) Secure Connection Issues
you need to remove the connection saved.
after securing the wireless router, before you try to connect. Go to
-Control Panel
-Network Connections
-Right Click your Wireless Adapter
-Click Wireless Network Tab
-Remove The Network
Then Try to reconnect.
Symptoms:
