I have a Hunter fan that is about 10 years old. The remote receiver stopped working. Unfortunately, Hunter has discontinued the part, 85112-04. This item works ...
Original Hunter Receiver 85112-04 (8511204000) is no longer available and is replaced by our FAN2R KIT. Works for: 3 Fan speeds Low, Medium, High, Fan ...
US$59.99 · ‎In stock
Find many great new & used options and get the best deals for Hunter Fan Receiver 85112-04 at the best online prices at eBay! Free shipping for many ...
Rating: 4.8 · ‎4 reviews
Delivery between Monday, May 24 and Tuesday, May 25. Order within 23 hrs and 28 min. This item is out of stock. We'll email you when it's available! Product ...
US$55.00 · ‎In stock
I have a Hunter 94974 fan receiver 85112-04. All remote functions work except it won't switch to the lowest fan speed. The red light goes on when I hit the button. Is ...
Hey dale. Sounds like either the integrated remote pack inside the fan housing might be bad, or the reversal switch part. If it has a switch on the fan housing to change it from forward and reverse, you could try going to a hardware store and replacing that switch. If that doesn't work, then it is probably a bad remote receiver pack iside the fan, it will be a bigger, probably black little box. If this is the case, your better off getting a new fan, as it will cost about the same. If your fan doesn't have a little switch to change blade direction, 9 out of 10 times it is the receiver pack. If your fan does have a switch for fan direction, there is a good chance it is a bad switch. It could also be both. After 10 years with the fan, you might seriously want to consider purchasing a new fan.
I realize that this is an old post. However, the best solution is to replace the receiver with 3 or 4 speed wire harness, which includes the capacitor, fan speed switch, forward/reverse switch and female plug for $15 as of today's writing. While you may be able to find a 85112-04 replacement receiver, I found them to be an expensive solution at $80. In addition, there is no telling how long the replacement receiver would last. To purchase a 4 speed wire harness for this Hunter fan, they can be ordered from Casablanca. Casablanca you say? Yes! Casablanca is a subsidiary of Hunter Fans. This 4 speed wire harness, part number K016501H01, is standard in many Hunter and Casablanca fans. Hopefully this will help someone looking for a low-cost solution to replacing the fan. Link below: http://www.casablancafanco.com/Parts-Manuals/Part-Manual-Detail?ModelNumber=54019
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
It is possible. Unless you know a bit of electronics, it would be difficult to do the conversion. You have to study the control circuitry of the old and new ceiling fan. You are lucky if it is a pin-to-pin direct conversion. An electronics techinician at your location can do it easily...I guess.
Unfortunatly that is a common thing with most manufactorers now a days! they are not in the service industry. make it, sell it, dump it, make a new one. and the cycle goes on and on. You may be able to find a repair person who can fix the fans for you at a reasonable cost.
