The lights work but the fan does not. You can hear a "click" when you press the remote control buttons for the fan.
Hunter fans have a limited lifetime warranty. I would suggest contacting Hunter customer service for diagnosis and repair guidance, or possible replacement. I've personally contacted them in the past with issues and they were very helpful.
I think you should purchase a new ceiling fan for your room. Try visiting www.ceilingfandirection.com . There are many varities of fan that can suit your room decor and best part is that ceiling fans are at half the price compare to other online vendors.
http://www.ceilingfandirection.com/ CeilingFanDirection
The roll was rusted maybe .you can take apart it for checking .
ceiling light
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
