The fuel filter on your Holden Barina is designed to remove any harmful dirt or debris from the fuel before it enters the fuel injectors. It is usually located with the fuel pump inside the fuel tank or in the fuel line between the fuel tank and the fuel rail.
It won't start because you need to reset the security system and engine immobilizer. The extra wire is likely to be an aftermarket accessory. Does it go into the wiring harness? What colour is it?
Holden barina tk 2007 engine won't start. ? run the fault codes check that the cam shaft is turning ( broken timing belt) check immobiliser for correct operation ...
Holden Barina P1700 OBD-II Diagnostic Powertrain (P) Trouble Code Information Page. Reason for Holden Barina P1700 and find the solution for the code ...
A Holden dealer with a body shop can give you this info or you can try any large body shop... If you ask them nicely they can look it up for you on their data bases. You may also be able to get the info from a specialist auto paint supply business in your area that does auto colour mixes for clients.
side of motor firewall side down near cv shaft that goes into gearbox if you look there you will see a 8mm bolt with the sensor going into the side of motor
these had issues of not starting when cold and missfiring only when cold
this was due to valves sticking due to carbon build up
head of and get valve guides modified as per holden info (scrapper counter sunk guides)
