Honda Portable Generator Model Ex1000 Logo
Alain Moreau Posted on May 16, 2016
Needto change seal between motor and generator
If the motor was ever filled with oil, will that blow a seal or gasket and cause it to leak out of engine.
if the motor was overfilled it would blow a seal on oil look at the to main seals being bad should be under warranty
1helpful
I have a oil leak on a coleman generator
Most likely at the output shaft of the motor. If you are handy, you might be able to replace the crankshaft seal yourself, but this will probably require you to seperate the generator from the motor, and remove the cover holding the seal. If the leak is small, it may be best to just keep adding oil. If you have to take it to be repaired, it may be more expensive than the unit is worth.
My coleman powermate5500 mod 0525500.01 leaks oil between motor and gen. how to fix
The crank shaft seal is bad on the motor. You will need to seperate the motor from the generator to replace the seal. Depending on the seal design, you will have to open the crankcase on the output shaft side to remove the seal.
1helpful
How to chanGe oil seal in generator
I have 2kva generator, i want to change the oil seal, so how can i dismentle the generator, pl guide me step by step
2answers
We can't get any music from Itunes onto our IPOD? It doesn't seem to register it either?
you dont needto register you just download music to the itunes and ask it to upload it on ti your ipod
Oil leaking from generator
Whose engine do you have? Briggs and Honda have websites where you can down load their manuals and replace the rear seal.
Top Honda Air Tools & Compressors Experts
ADMIN Andrew
ADMIN Andrew
Renee Knafel-Bullock
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
