JVC GZ-EX210 Full HD Everio Camcorder with WiFi Black GZEX210BUS Logo
Kevin Gragnani Posted on May 14, 2016
I cannot use the touchscreen
Is there a way that i might have locked the screen
1helpful
How to use touchscreen because its on but not working to open the screen of the tablet
Is it a password issue that is locking the screen? The manufacturer will have some instructions on how to fix this problem.
Touch screen not working / not registering touch
Follow the steps mentioned below until your problem is sorted.
1. Restart Your Android Device It works 80% of the time. Screen locking/managing applications often make touchscreen unresponsive. In that case you need to restart your Android device. How can I reboot my tablet, the touchscreen is not working.. Good question!
  • Grab your Android tablet/phone
  • Press and hold the Power Button for 10 seconds or until the screen goes blank.
  • Wait a minute or two and then power on your device normally using the same button.
2. Eject Memory Card and Sim Shutdown your Android device and remove the Memory card and Sim(s) attached to it. Also, remove the battery for few seconds if possible.
3. Remove Any Cases Smart cases are good in protecting your device from scratches and damage. But their automatic screen wake/sleep feature sometime cause the device to malfunction. Remove the case, perform a restart.
4. Hard Reset your Android For advanced users. If everything else doesn't work, try doing a hard reset on your phone. This will wipe your phone/tablet and return it to its original condition. This usually involves holding down Volume-Up and Volume-Down button together and then pressing Power Button (every phone has different method). It starts your device in Recovery mode, you can do a Wipe-Factory-Reset from there. Use volume up/down buttons to navigate and press Power button to select. Be careful and don't mess with other options or you may brick your phone.
5. Knocking the Touchscreen (Not recommended) Remove the Screen Protector on your Android device if present. Now, gently knock every corner of your touchscreen to realign it. Sometimes continuous phone drops cause screen digitizer cable to loses its connection to device motherboard however, its a rare case.
If you are still unable to make touchscreen work maybe its time to claim warranty, Its a lengthy process but works. Also, post comments below to share other tips not mentioned in this article.
May 29, 2015 • Cell Phones
Touchscreen not responding on Alcatel 4015t
seems like the phone is locked in restricted sight mode.
How do I get my trio to go back to the home screen?
It could be that your touchscreen (digitizer) is PARTLY broken.
To confirm, try rotating your tablet 180 degrees, and then touch the home button again.
If it works when rotated then you need a new touchscreen.
I hope you are good with precision tools, and have good mechanical skills and instincts: it's a rather intricate job to locate the locking tabs and screws that attach the touchscreen to the insides of the tablet, then remove them, and finally to replace a touchscreen. And then reattach all necessary fasteners, and test whether it will work properly.
EASIER FIX: go to Ebay and buy a used Trio tablet. it may cost you only $40 to $50 maybe even less!
Getting a lock while scrolling
My S3 constantly triggers the screen lock whenever it is touched. How do I turn this feature off?
LG touch phone. Touch screen keeps blanking out, it that the touch screen will not work. Screen shows everything but the touch of the screen does not work. I have took out the battery and replaced it. It...
when phone is idle, the auto lock feature locks out the screen. you can set the time when lock engages or disable completely. To unlock, press top right corner button or use touchscreen options by sliding finger up from bottom to top or press unlock button on bottom of touchscreen
Nuvi 760 powers on but the touchscreen will not work
If the Touch Screen is not working properly, Calibrate the touch screen..
Turn he unit off then on.... Slide Power Key to the right ( lock )
Hold finger on screen for about 30 seconds until calibration screen appears... for on screen instructions
1helpful
Touchscreen not respondent
The touchscreen is defective and needs to be replaced. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
2helpful
Screen works but dosent respond to any touching?
Check that the "touch screen lock" is not engaged. To avoid accidental activation of the touchscreen, many models use some kind of "security" so that after a fixed time, the touchscreen will stop responding unless you (e.g.) click an unlock button. Verify this on the user manual.
2answers
My MC70 work symbol wont respond to my touch screen pen
Does it respond to keyboard entry? If not, check to see if the "lock" icon on the screen is in the locked position. It's real easy to accidentially lock the device. If it is, just click on the lock and confirm that you want to unlock.
The next few can be a problem if the screen is not responding, so you'll need to figure out the keyboard equivalent:
You may also want to check the system settings. I believe there is a setting that will enable you to "turn off" the touch screen function.
Finally, try a touchscreen alignment in the system settings.
Jan 17, 2009 • Symbol MC70
Top JVC Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a JVC Computer and Internet Expert? Answer questions, earn points and help others
