Just bought this online and find it won't run on new tested AA batteries. If plugged into AC power it works just fine, but when plug is pulled just gives the blinking flat battery symbol and shuts off. Any suggestions please? Mark
SOURCE: Inspiron laptop Battery won't charge
Hi
Update laptop bios go dell.com check for update of your laptop model....
Thanks
SOURCE: Laptop won't turn on, battery and power lights keep blinking
Looks like you are having a no post situation, generally a failed motherboard. Replacement motherboards are available on Ebay for around $100
SOURCE: hp compaq nx9110 runs only on battery when it is plugged to AC
It sounds like you have a faulty power jack, and possibly a dead battery as well. You should take it to a person you may know that can order and solder a new one in or take it to your local electronics repair shop. I do repairs like this on a daily basis for my computer business.
Try taking out battery and plug in power. If it works, battery is faulty. If not,
Try taking out your hard disk plug in power, if it works, hard disk is faulty. If not,
Try taking out memory card, if there's a sound, memory card faulty. If no sound, it's your motherboard that is causing the error.
Note: If machine is under warranty no need to pay for the repairs.
SOURCE: Gateway MA7 (MX6955) Will not boot up, or power
hold on i have a gateway here let me see if it does or not.nope mine works without battery i had to push the power button a couple times but it fired up.could be your MB
