Cars & Trucks Logo
A
Anonymous Posted on Apr 05, 2016
Can I put 5-20 synthetic oil in a 1997 Toyota car
clark
Level 3:
Genius:
  • Toyota Master 1,288 Answers
  • Posted on Apr 05, 2016
clark
Toyota Master
Level 3:
Genius:
Answers
1288
Questions
Helped
334265
Points
6770
Sean Piquet
Level 3:
  • Toyota Master 1,867 Answers
Sean  Piquet
Toyota Master
Level 3:
Answers
1867
Questions
Helped
610949
Points
7259
Provided you use the correct grade of oil as stipulated by Toyota for your engine(you have NOT identified your model and engine)(check your owners manual) and provided you use the formulation suitable for Toyota engines you will be fine using the correct grade fully synthetic oil. There are sometimes 2 or 3 different formulations in exactly the same grade for some oil brands so make sure you select the correct one.
Some oil companies offer oil selector programs for customer use on their web sites so if unsure use these systems to ensure you are using the correct oil..
5 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jun 02, 2009
SOURCE: best synthetic oil and battery
Mobil one or Castrol brand, use 10W-30W, the best battery around is made by Delco (they make a battery for your car), yes that is GM.
shortyb240
  • 25 Answers
  • Posted on Oct 23, 2009
SOURCE: i don't know what weight of oil my car takes. i
You can get a professional consult free from mobile 1 at 1800 033-0863. It appears that 10w-30 and 10w-40 are commonly used in this make but the climate you live in could make a difference as well as your driving style. If the engine runs hot you'll want a heavier weight possibly but if you are in a cold climate that might not be the best thing. I'd call the number.
Ralph Cronenberg
  • 449 Answers
  • Posted on Sep 01, 2010
SOURCE: my girlfriend took her 2007
its better than the regular oil
Anonymous
  • 98 Answers
  • Posted on Sep 07, 2011
SOURCE: Is it safe to put
It depends on if the oil already in the car is synthetic of conventional. If the oil in the car is synthetic already you will be fine adding that. If it is conventional you will want to do a complete oil change and change the filter.
Hope this helps.
GeoffW1
Geoffrey White
  • 3965 Answers
  • Posted on Mar 21, 2012
SOURCE: can i use full synthetic engine oil in a Toyota corolla 1997 ?
Yes, but there is no point to doing so. Just use ordinary oil and change that and the oil filter at the minimum intervals.
1helpful
Can i use full synthetic engine oil in a Toyota corolla 1997 ?
1helpful
Don't know if the oil in the vehicle is synthetic or not - what is the safest option to top up with? Semi-synthetic?
Might as well add synthetic, it will not hurt it either way but it is best to put synthetic over oil.
I have a 1997 mercury grand marquis es in was wondering do it excepts synthetic oil!! if do what kinds????
The car maker suggests that this car engine use synthetic motor oil 5w20 synthetic oil, hope this is helpful, also it holds 5 qts of oil.
WHAT OIL TYPE FOR 1997 TOYOTA 4 RUNNER
Toyota,Europe use 10/40 semi synthetic,for all their cars/suv.they are even supplied from the factories worldwide with this grade of oil.
as they have a world contract with shell.
2helpful
What engine oil do you put in a 1997 twin turbo legacy gt
the best would be a fully synthetic that still remains relatively thick(comparitvely speaking for synthetics as theyre known for being thin oil) very runny,but get something thats 10w 40 or 10w 50 unles you live in the snow then thin synthetic is fine,unless the engine has done heaps of miles,even semi synthetic if youre on a budget,but minimum
7helpful
3answers
Not sure what type of oil my 97 corolla takes
My 97 CE takes 5W-30...it should be marked on top of the oil filler cap on top of the engine.
1helpful
What kind of oil do you use in a 1989 Toyota supra? Its an automatic and does not have turbo.
britty1411: According to Toyota
API: SG multigrade or better. 10W-30 above 0 f
Personally I put Castrol 10W-30 GTX in most of my customer cars unless they want to go synthetic.
Use a good quality oil filter.
3answers
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
