Scan it and see the exact code for the CMP
CMP is the cam sensor. (failing)
we cant guess what country you are in, nor what engine is there.
there are like 6 engines, used.
to ask a question on a car on a USA forum tell country first then engine. and if savvy?, which if 4 transmissions. there.
1.5 L M15A I4 (petrol)
1.6 L M16A I4 (petrol)
2.0 L J20A I4 (petrol)
2.0 L J20B I4 (petrol) (common on USA< with VVT cams)
1.3 L D13A I4 (diesel)
1.6 L DV6ATED4 I4 (diesel)
1.9 L D19A I4 (diesel)
2.0 L D20A I4 (diesel)
dont ask where it is,until above is know,, see?
Best Manuals
to fix your car go to this link
Observe the scan tool CMP Desired, Actual, and Angle Variance parameters before a DTC sets. This may help to isolate whether a condition is specific to one camshaft, one bank, or caused by a condition with the primary crankshaft timing.
DTC Descriptors
DTC P0010: Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit Bank 1
DTC P0013: Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit Bank 1
DTC P0020: Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit Bank 2
DTC P0023: Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit Bank 2
DTC P2088: Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit Low Voltage Bank 1
DTC P2089: Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit High Voltage Bank 1
DTC P2090: Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit Low Voltage Bank 1
DTC P2091: Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit High Voltage Bank 1
DTC P2092: Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit Low Voltage Bank 2
DTC P2093: Intake Camshaft Position (CMP) Actuator Solenoid Control Circuit High Voltage Bank 2
DTC P2094: Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit Low Voltage Bank 2
DTC P2095: Exhaust Camshaft Position (CMP) Actuator Solenoid Control Circuit High Voltage Bank 2
DTC P0341: Intake Camshaft Position (CMP) Sensor Performance Bank 1
DTC P0342: Intake Camshaft Position (CMP) Sensor Circuit Low Voltage Bank 1
DTC P0343: Intake Camshaft Position (CMP) Sensor Circuit High Voltage Bank 1
DTC P0346: Intake Camshaft Position (CMP) Sensor Performance Bank 2
DTC P0347: Intake Camshaft Position (CMP) Sensor Circuit Low Voltage Bank 2
DTC P0348: Intake Camshaft Position (CMP) Sensor Circuit High Voltage Bank 2
DTC P0366: Exhaust Camshaft Position (CMP) Sensor Performance Bank 1
DTC P0367: Exhaust Camshaft Position (CMP) Sensor Circuit Low Voltage Bank 1
DTC P0368: Exhaust Camshaft Position (CMP) Sensor Circuit High Voltage Bank 1
DTC P0391: Exhaust Camshaft Position (CMP) Sensor Performance Bank 2
DTC P0392: Exhaust Camshaft Position (CMP) Sensor Circuit Low Voltage Bank 2
DTC P0393: Exhaust Camshaft Position (CMP) Sensor Circuit High Voltage Bank 2
I'm sorry but when dealing with these problems your best bet is to take your vehicle to a qualified repair shop , I have never see a DIY'ER correct the problem with these , an in the end always end up taking it to the dealer .
