Re: My iphone 6s is stuck on the screen showing a plug...
You need to plug in your iPhone 6s to computer and use iTunes to get it out.
Step 1. Hold both the Home and Sleep/Wake buttons down for a minimum of 10 seconds, or until the device turns off.
Step 2. Push the Sleep/Wake button again to turn on your iPhone. If your iPhone is not in Recovery Mode, the problem is resolved. If it still sticks, continue to step 3.
Step 3. Launch iTunes and connect the iPhone to your computer. You should see a notification in iTunes says that iTunes has detected an iPhone in Recovery Mode. Click Ok.
Step 4. Click the device icon on the left side of the iTunes window, and select the "Summary" tab.
Step 5. Click the "Restore" button. The Most Common iOS 9 9 2 9 2 1 9 3 Problems and Quick Solutions
This guide collects the most common iOS 9 9 2 9 2 1 9 3 problems and also offers the quick solutions so that you can upgrade to the latest iOS version smoothly
Jared, Sounds like you may have to do a hard reset and see if it gets you out of the predicament. If not then you may have to do a factory reset.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Probably something went wrong, and your iPhone itself sees that too. That's why your iPhone asks to connect it to your PC or Mac with iTunes installed.
-Start iTunes on your PC or Mac
-Connect your iPhone to the PC or Mac
-Probably iTunes will advise to recover your iPhone.
>>If you didn't make regular backups of your data you probably will lose the data that's on your iPhone.<<
-Wait until the recovery procedure is done and see if your iPhone works again.
What if iTunes doesn't recognize your iPhone anymore in iTunes?
Thy a "soft reset' by pressing the ON/OFF button on top of your iPhone and the round menu button underneath your screen simultaneously until your iPhone reboots. Check if your iPhone connects to iTunes and try the recovery.
I hope this will help you solving your problem.
I'm afraid you probably have a bad sim. I had a similar problem with a sony ericsson. phone would reject the sim, but a telco rep was able to recover data
