Any wear or play in a bush or rod usually gives a 'knock' or causes vibration, not a humming noise.
If there's play in the steering wheel that may be due to a worn steering rack and pinion.
A worn ball joint can cause a 'crack' noise and depending on the wear, vibration that will be felt through the steering wheel. A worn ball joint can also cause the car to pull to one side.
A humming noise suggests it is either a brake rotor/pad, or a worn driveshaft or wheel bearing.
