Biometric fingerprint at start up wont read my finger
Cannot get into bios or any other F key at startup tried reinstall cd it wont read also tried an usb cd reader also did not work is there a way to remove this finger print program
cause at the moment the pc does nothing
the program is called vitakey / MY winlogin
tried this doesnt work its a hardware problem i contacted the company who makes the laptops and they say its an anti theft system and that im now logged out of the motherboard untill i use a password that i do not have noir a finger that works to unlock it again so unless someone has a hack or hardware override to fix this problem i got a expensive piece of plastic i guesstried this doesnt work its a hardware problem i contacted the company who makes the laptops and they say its an anti theft system and that im now logged out of the motherboard untill i use a password that i do not have noir a finger that works to unlock it again so unless someone has a hack or hardware override to fix this problem i got a expensive piece of plastic i guess
I had not experienced this issue as of yet. If you miss the warnings and the battery goes dead on you, the unit comes with a key that will open it manually. The fingerprint scanner of the Barska Biometric Safe is easy to set up. The advanced biometric technology used allows for up to 30 fingerprints to be stored. This means no memorizing combinations or fumbling around for keys whenever you are faced with a high danger situation. Simply touch the scanner with the recorded finger and in about 3 seconds, you're well in the Gun safe.
From the description it is a software problem, If you were sticking things in the scanner bar that would not help and it will prevent the laptop from working.
Trinity Keyless Biometric lock: I can't answer your question directly, but I can steer you to their website, which includes a support phone number that you can call, as well as links to Customer support and Frequently Asked Questions:
uninstall the Protector" Suite (finger print scanner software ) and restart it and check .....
if its not happening try in bois..... restart your laptop hit F1. then navigate to the integrated devices, there will be an option to enable or disable the finger print scanner there.
contact sentry
biometric scanners DO NOT WORK
prove your ownership
and they may assist you
and
The Acer Bio-Protection fingerprint solution basically lets your network and data be secure by verifying an individual's true identity. The integrated biometric fingerprint reader supports Pre-Boot Authentication for secure authentication during system power on even before the operating system starts which means Windows shall authorize you to Log-in on just a mere touch, without the need of typing in passwords.
Look on the task bar next to your system clock and you will see a "key" icon. Double click on that icon and have at it. If for some reason the Icon is not visible, look in the bag of CD's provided by Acer, there ought to be a utility inside.. :-)
Yes, you have a nice door stop.
