To replace the ignition coil on a strikemaster solo ice fishing auger you will need to go about it from the bottom side. remove the auger drill itself and turn the unit upside down. remove the 4 screws and the snap ring remove the screw that connects the throttle arm. remove the remaining bolts that hold the upper part of the gear case and remove the entire gear case unit. now you will be able to access the screws that hold the plastic cover and have access to the coil.
SOURCE: Replacing Auger in ice maker
Kim There are two Screws Holding the Complete Ice unit in Place,After Removing it it unpluggs inside the freezer,It would be advised to Replace the whole Unit ttech
SOURCE: Ice maker auger not turning
WELL DID YOU GET THE PLUG OUT OR END UP CALLING SERVICE ?AND FOR MY HONESTLY GOOD OPINION AND TRUTH IN ADVISING YOU!
YOU GAVE ME AN INAPPROPRIATE RATING AT FIXYA.COM
Shame on you! I know, sometimes the truth hurts!
BLESS YOU ANYWAY NGFAM1
There are many parts in this component that may be the culprit .
One or more will need to be replaced.
This is not easy to diagnose. I've seen service order parts 2 or 3 times till they completed the ice maker repair on a side by side fridge!
You need a hands on tech for this repair!
SOURCE: Ice will not come out of the door. The auger is not turning
take the ice bin completely out and run water in it until all the ice is clear from the auger
SOURCE: How to replacemale gear for ice auger on 2003 whirlpool side by s
Here is a place that has an exploded view of your icemaker, and mounting: http://www.pcappliancerepair.com/model-display.php
On the left side of the page, scroll that view down until you see the freezer door parts, and click on the words. This will bring up the proper view where you can see where the screws etc are that hold the unit in.
They, as well as the several other places I checked, show the auger motor as a sealed unit, that you get to by removing the icemaker from the door.
SOURCE: GE PS123 MGNA CC Ice Auger
I just finished replacing the ice auger in my GE HSS25GFPA side-by-side and offer some suggestions/hints.
The auger (WR17X11705) was available locally (Appliance Parts Co., $28.97). This fits many other refrigerators. The replacement took a little under 2 hours. I estimate these hints may cut the time by one-half.
There are only 4 screws in the entire ice drawer assembly. It possibly was not necessary to remove the control rod. The other 3 screws hold the front cover. There are also 2 tabs holding the top of the cover.
The most difficult part of the repair was removal of the plastic assembly housing the crusher blades and the front bearing of the auger. This is held in place by only 2 large square tabs on the sides. There is enough space to get ONE side to release BUT to get both released required careful prying with thin-bladed screwdrivers (and prayer). These "tabs" don't push in, rather the drawer flexes out. Once released, the unit slides up and angles to allow removal of the auger/crusher. Re-assembly could not be easier. Stainless sheet metal screws would probably work if you do break something.
Remove the clear inside cover of the crusher assembly and the "C" clip on the threaded end of the auger shaft to separate the auger from the crusher.
And now for my PRIMARY reason for sharing my experience - the %#$@ plastic nut/bearing is a LEFT-HAND THREAD. I only realized this when trying to bend my make-shift split screwdrive back and the SOB loosened right up!
Carefully note the locations and orientations of the blades and spacers as you move them from the old to the new auger.
