I turn it on, the screen lights up, but there is no image. This happens whether or not there is a tape loaded, and in both CAMERA and VTR modes. The eject works, and the zoom works, there's just no image on the display screen. I charged the battery fully. It hasn't been used in years, and I'm not sure it it was working when our new camera was bought. I like to think that it's not dead yet, but my hope is fading. If there's anything I can do, please tell me. Thanks.
SOURCE: Playback & Ejection Problem
Hi, You usually get an EJECT TAPE when the camcorder has found an internal problem and either the videocassette or the camera itself has developed a problem. In you case, it looks like you tape has a problem. Daniel
SOURCE: no power Sony Handycam Model CCD-FX620
there are fuses ,but they are small solder in types, all fx series camcorder have a common problem with the rear power board working it's way loose and unplugging itself from the main board. these units have alot of solder connection issue due to sony's use of poor solder back in the earily 90's
SOURCE: Canon MVX200 will not load dv tape
The "remove Tape" error message on Canon DV camcorders is a general message meaning something is not correct with the tape transport system. These are miniature precision mechanisms and It could be anything from dew sensors to head motor, capstan drive etc. If the cassette drawer closes OK with no tape inserted then the tape sensor/ end tape sensor is operating. With no tape inserted the head drum does not run when the drawer closes but it does with a tape present. Does the head drum start up when you load a tape or is there no noise at all? If the head runs then it is possible the capstan is not starting or is jammed. If the head does not run then the cure will be either extremely tedious and delicate or very expensive. These units do not dismantle easily so unless you have some experience with this, or are willing to take a risk, then I would not recommend it. However, without such action you may have to write-off the unit anyway. Canon's repair charge will exceed the camera's value unless it's still under warranty. Your best option would be to find a local repairer that is willing to look at it, but I wouldn't be too optimistic .To some, this error message is a major issue when deciding to buying canon dv cameras. However, they are great little cameras and treated kindly will give many hours of excellent service. Don't store the camera with tapes loaded. don't subject it to sudden temperature changes or excessive vibration. Store it in a dry protected atmosphere and refrain from taking it onto the beach (salt AND sand !!!!) when on holiday etc.
SOURCE: Tape Ejection Problem
I have both the willful zoom and the unwilling cassette problems. In the past I have briefly fixed the zoom by opening the door and gently probing the cable to the zoom button. This only worked for a couple of weeks then reverted to same crazed performance. Then last month the "remove the cassette" madness started (bear in mind, I have only recorded perhaps 15 cassettes on this damn thing). Nothing worked. Until tonight when I simply lightly smacked the unit down flat on the manual resting on my desktop. Did this a few times and BOTH the zoom and cassette door started responding properly. I'll see how long this lasts, but it beats buying a new one or dealing with Canon. Never again.
SOURCE: Tape wont play or eject.
i just read about this c:31:22 problem while looking for a solution to another problem I am having. Someone suggested removing the battery, switching the camera to the "camera" setting, and then turn it off, put the batter back in and it should work. Good luck.
