20 Most Recent Sony Handycam CCD-TRV108 Camcorder Questions & Answers
Not to be a smart-@$$, but lens cap is off and it is powered on and set to the correct mode?
Sony Handycam... | Answered on Feb 13, 2012
Play the tape in the Camcorder and connect it to the TV using A/V cable.
Sony Handycam... | Answered on Jan 29, 2012
Inside your camera there is mechanical movement when you zoom. There is a motor that turns a wheel is connected to a belt with teeth that goes to your lens. this moves the lens in and out. If a screw on this assembly is loose then anything of that sort can happen. You to have the lens assembly opened professionally then check if the belt and motor are still running properly and if the assembly is not loose. You can tighten the screws or if something is cracked you can use superglue to join it together. Using it like that will make the situation worse and it might stop working.
Sony Handycam... | Answered on Nov 19, 2011
This is a fault in the loading section and so unless the camcorder is pulled out it is not possible to get a clear look into the circuits and mechanism.
It needs to be checked if there is voltage on the loading section from the loading IC and also if the motor loading mechanism is in order. Sometimes the gears, belt or pulley can be faulty.
If not the loading driver IC can be faulty . finally check on the eject microswitch.
Attempt only if you are equipped.
Sony Handycam... | Answered on Aug 11, 2011
You will need an Analogue to Digital Converter box to get the signal to a computer.
Use the RCA video and audio connectors (yellow, red, white) to go from camera to A/D Converter and then a firewire cable from the A/D Converter to the computer assuming the computer has a firewire port.
Firewire is also caleed IEEE1394 or iLink.
Sony Handycam... | Answered on Mar 03, 2011
Please remove the tape from the camcorder while it uses for streaming purpose and it will resolve the issue
Sony Handycam... | Answered on Jan 26, 2011
your sony ccd-trv 108 will transfer videos(stream) to a computer using firewire connection. install the supplied software or use any program compatible for streaming like windows movie maker. use a firewire cable. check your computer for a firewire port(port with IEEE symbol) make sure that the tape is totally rewounded then press the record button on windows movie maker as the same time as you play the video from the camcorder. (its basically playing the entire video in order for windows movie maker to record it.
Sony Handycam... | Answered on Jan 25, 2011
Hello, you should be able to download the manual from the Sony website. :)
Good luck
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CCDTRV108
Sony Handycam... | Answered on Dec 23, 2010
Your battery is wear down is wear down and need the replacement
Sony Handycam... | Answered on Dec 20, 2010
The error code C31:23 denotes that the problem is in mechanism(which is misaligned) of loading section and it need mechanical adjustment by an expert. Contact any expert nearby and pay labor charges because no part is required to resolve this issue.
Thanks
Sony Handycam... | Answered on Nov 25, 2010
This can be caused by several problems including the transmission gear in the tape mechanism not engaging properly or a defective clutch in the take-up spool and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Sony Handycam... | Answered on Nov 20, 2010
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
Sony Handycam... | Answered on Nov 06, 2010
The pinch roller is held in place by a pressure connector and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be diagnosed by a qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
Sony Handycam... | Answered on Sep 03, 2010
that is your lcd door switch inside the cassing its have to be replaced ..
its not a big job but have to be made by a tech
regards Allan.
Sony Handycam... | Answered on Sep 01, 2010
I need following info to diagnose problem of your camcorder.
Do you get correct picture in playback of old recorded tapes?
Is it Sony CCD-TRV108 camcorder or any other model?
Let me know above info to provide you solution.
Thanks.
Sony Handycam... | Answered on Jun 28, 2010
O heck my camera too went like this, it turned out to be the lamp in the camera that lights up both camera screens, everything looked really dark with out that like, and wow not cheap mend for me, as they charge a bit for the bulb about £4 in UK, but the man who does the job must be paid around £60 per hour, and that hurt, now do you need a box of hankies as I still got couple left.
Sony Handycam... | Answered on Jun 05, 2010
C:31:22 T reel fault. Load the tape again, and perform operations from the beginning.
Sony Handycam... | Answered on Jun 04, 2010
I had one of these before I bought my new Hi 8 digital camera, I would be keen to ask what problem have you got that needs this job doing? I know that the small black screws on the top and back allow the outer case to be removed, but you will find that most of the things that go wrong are more electric items rather than mec side of things, so most type of problems the man in the street could not repair anyway.
Sony Handycam... | Answered on May 21, 2010
Sony Handycam CCD-TRV108 Camcorder Logo
61 questions posted
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Parshiv Luthra
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
View Most Popular
Handycam Sony
  • Handycam Sony
Most Popular Question
keep camera from shutting off im
  • Video Cameras
