O assume you are wanting to add a sub as bose systems are already amplified. The short answer is ues, however most bose systems require special interface harnesses and may require complex wiring. This is best left to a qualified mobile electronics shop.
each speaker in your car runs the wiring thru an amp. So each spkear has its own amp for the bose system. You can not hook up a none bose radio If you do you will need to run new wires and replace all the speakers. Sorry.
If no Amp is used, connect jacks ( Left, Right) from your receiver output to Bose equalizer Input ( L, R) where it says Amplifier. Then also under where it says Amplifier, connect jacks from Output to your speakers. This would require the type of speaker wires that are RCA (plug in, red and white) on one end bare wire on the other to the speakers.
I don't know what the output is on your Kenwood, but if it's low watts, an amp is much better to crank those Bose. It's a different connect with an amp. Go L &R from the receiver to Equalizer as before, then from equalizer to amp Input where it says Tuner. then hook bare speaker wires to back of amp to Bose speakers.
You should have full use of Bose controls. The Monitor button is for an extra component that can be hooked up on the back, right side of equalizer.
hi! you can hook up .. first if your bose amplifier have a phono input you can put it plug and play. but if no pre amp phono input you have to buy or provide (from turntable to pre-amp phono to bose) to heard and listen to your old vinyl..
mk2 batallion.....
The Bose system in the Z is wired to control the entire car's speakers. Each speaker has its own amplifier, and the OEM head unit puts out a line-level signal to each amp. Your Clarion unit puts out speaker-level signal (in effect, an amplified signal), into the Bose amps, and it's probably overdriving them and putting them into shutdown.
Your best bet is to replace the Bose speakers with aftermarket speakers meant for a speaker-level drive (which is what I did in my Z, and never once regretted it). If you do so, you'll need to run new wires to the speakers, or if you use the OEM wiring, you'll need to unplug the amps and run the wires from the amp harnesses directly to the new speakers. I think there is an adapter harness you can use that will tap into the line-out jacks on your Clarion, so that a line-level signal can be sent to the Bose speakers - I'd do a google search for "Metra harness 300zx" or something along those lines (Metra makes the lineout harness adapters - I use one in my Audi).
yes, you'll need to purchase a "line level converter" to change the speaker connections to RCA connections. Or buy an amp that accepts speaker level inputs and extend the wires to the amp. If you have Bose system (says "Bose" on speakers), this will be different since you already have a factory amp
The trunk mounted 12 disc magazine changer with the Bose audio system is made by Pioneer. Mine is a bit flaky too so I try to avoid unnecessarily swapping out the CD's. Those error codes can mean anything from a defective/wrong disc type (it does not support MP3 discs), a disc being upside down, or forgetting to close the magazine loading door. It can also indicate condensation on the laser lens or a system malfunction. There may be a list of error codes in the owner's manual if you have one, I currently don't.
Assuming you have checked all of the possible human errors above, there are aftermarket sellers that claim you can adapt an aftermarket changer to the Bose system albeit with with inferior sound quality to the original system. Bose is typically well-known for it's audio quality. That being said, the other option would be to seek a repair facility that can repair these changers. There are some places on-line that repair car audio that also might be able to help.
A cheaper workaround might be to hook up a portable CD/MP3 player using a cassette adapter. Assuming the cassette player, amp and speakers are good, you would possibly still get fairly high quality sound from the Bose system.
