Cars & Trucks Logo
A
Albert Posted on Jan 25, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2000 ply. neon wont shift into overdrive - Cars & Trucks
Claude Kayser
Level 3:
Top Expert:
  • Cars & Trucks Master 9,098 Answers
  • Posted on Jan 25, 2016
Claude Kayser
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067818
Points
28436
Plymouth transmission wont shift into overdrive Questions ...
www.fixya.com > Forum > Tags > transmission wont shift into overdrive
Plymouth transmission wont shift into overdrive related problems. Ask your Plymouth transmission wont shift into ... My 2000 plymouth neon is stuck in park.
Dodge Neon Questions - my neon will not go into overdrive ...
www.cargurus.com > Questions > Dodge > Neon
CarGurusSep 14, 2012 - my neon will not go into overdrive, it stays at 3500 rpms on highways - my neon does not ... 2003 Dodge Neon won't shift out of park 5 answers.
part2 replace the shift solenoid and speed switches in a ...
? 7:15
https://www.youtube.com/watch?v=2ETvtt8fcr4
Sep 10, 2009 - Uploaded by Sean Conley
Dodge Automatic Transmission Removal - Duration: 11:05. ...Dodge Neon Crushed By Mud Trucks ...
Wont shift gears
Dodge Neon Questions - 04 neon will not go into high gear ...
CarGurusNov 3, 2012 - 04 neon will not go into high gear - 04 neon won't go into high gear. changed transmission fluid. (it tried to change after fluid was changed) gas cap ... ... Car: 2003 Dodge Neon SXT, automatic transmission. As of today, I have ...
Dodge Neon Questions - 2005 Dodge neon does not shift ...
CarGurusApr 6, 2014 - Your cars computer gathers info on speed in order to shift gears properly.... then you won't have a speedo and the ECM will not tell the TCM to shift gears in the trans. .... Car: 2003 Dodge Neon SXT, automatic transmission.
Neon wont shift out of first gear auto. - DodgeTalk : Dodge Car ...
www.dodgetalk.com > ... > Dodge Neon - General Talk
Jul 30, 2011 - I have a 2003 dodge neon se and it will run and drive. The transmissonwill not shift out of first gear. Where do I start? Compare to Toyota Tundra. Get Tundra on ... 2000 Stratus won't shift out of First Gear
Mar 14, 2007
Not shifting out of Second Gear???
Jan 15, 2007
46RE wont shift out of first at full throttle.
Nov 17, 2006
Transmission wont shift
Nov 3, 2005
More results from www.dodgetalk.com
2answers
2000 GMC Jimmy won't shift to overdrive. New seal, screen, & sensor that shows what gear it is in and fluid changed. Worked for 3-4 weeks now "Service Engine Soon" light on and having same symptoms.
The Internet, though, has a large number of web sites where
you can buy service manuals and schematics from bookstores,
publishers, and other collectors. Here is just a sampling of
what sites are out there:
Chilton Repair Manuals
http://www.chilton.cengage.com/
Haynes Publishing
Haynes auto manuals
Haynes is the information resource for the DIY enthusiast
Factory Automanuals
http://www.factoryautomanuals.com/
Factory Auto Manuals is specialist dealer in quality used factory car...
Vintage Books
Vintage books com Rare used and out of print books
AutoLit
http://www.autolit.com/home.htm
Check engine light came on 5 mile down road transmission would not shift into overdrive
take it in and have them get the code/codes. probably a cheap sensor. could be cam shaft sensor or crank sensor i'm guessing
High rpm in 1999 ply neon
I can't see the car or know the complete history, but with that many miles it would need to be way below book value.
The car overall was designed to last about 150k in my opinion.
If the check engine light is not on, there may be something broken in the transmission to keep it from shifting into overdrive.
If the check engine light is on the code could point you in the direction of a solenoid or other electrical part.
I would not buy it unless you are prepared to spend the money to replace the trans.
1996 honda accord wont shift into overdrive
For Automatic transmission problem,click the link below:----Overdrive light in the dash blinks? http://repairhelpcenter.blogspot.com/2012/01/overdrive-light-in-dash-blinks.html
--------- Automatic transmission troubleshooting:----
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Automatic transmission shift lever issues?-------
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
AUTOMATIC TRANSMISSION FLUID LEVEL? --
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-automatic-transmission.html
AUTOMATIC TRANSMISSION FLUID AND FILTER?
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-automatic-transmission.html
Transmission fault light on car dash?
http://schematicsdiagram.blogspot.com/2011/12/transmission-fault-light-on-car-dash.html
Transmission shifting problem?
http://schematicsdiagram.blogspot.com/2012/01/transmission-shifting-problem-on-toyota.html
Transmission Slips out of 2nd gear?
http://repairhelpcenter.blogspot.in/2012/02/transmission-slips-out-of-2nd-gear.html
OD light flashing and transmission fluid leaking?
http://repairhelpcenter.blogspot.in/2012/02/od-light-flashing-and-transmission.html
Why Transmission fluid leaks near radiator?
http://repairhelpcenter.blogspot.in/2012/02/transmission-fluid-leaks-near-radiator.html
Transmission fluid leaking?
http://technoanswers.blogspot.in/2012/02/ford-windstar-transmission-fluid.html
****** wont go in reverse?
http://technoanswers.blogspot.in/2012/02/dodge-neon-wont-go-in-reverse.html
Automatic transmission will not go into reverse?
http://technoanswers.blogspot.in/2012/02/dodge-automatic-transmission-will-not.html
Transmission is making buzzing noise?
http://technoanswers.blogspot.in/2012/02/transmission-is-making-buzzing-noise.html
This will help.
Thanks.
Can I put a overdrive transmission in a 2000 neon with a 3 speed transmission
count the trany bolt holes youhave on both trannys, and the lines should tell you, But i really don't think you can because the shifting cable would be on wrong side, Hard to tell good luck.
2000 grand prix w/auto transmission wont shift into overdrive
some of the trannys has straps in them that sometimes needs to be tightened and that could be the cause of it
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
