"E06" it is the carriage mechanism that has failed. and will
not carry the tape to the heads and thus is not passing the sensor that
tells you if the tape is in position and then telling the unit as it
should there is fault.
take it to the nearest dealer and get it fixed.
www.fixya.com/support/t14040885-e01_e06_codes Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
Try this solution I found on a German site. Other sites I found did not even mention E06 as possible. Site is linked below, you can use GoogleTranslate to convert to your own language. Good luck!
Error E06 Canon MP287
The characteristics or signs:
Currently in turn on the printer does not print the worksheets.
ALARM indicator light lit In follow with lights flashing orange ink information.
LED indicators display appears on E06
How to Reset Error E06:
Press and hold the stop / reset until the standby light green and then release.
If the indicator light still flashing again, repeat again by pressing the stop / reset.
LOOK UP ON LINE TYPE IN E06 OWNERS MANUAL OR E06 PARTS MANUAL MAYBE ONE OF THOSE WILL SHOW YOU WHAT IT MEANS THE E USUALY STANDS FOR ERROR. THE 6 COULD MEAN THE OVEN OR BROILER OR A CENCER.
If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/ Error code details to many brand TVs are given.
