Whirlpool Duet: WFW94HEXW Laundry : Front Load Washers Logo
Question about Whirlpool Duet: WFW94HEXW Laundry : Front Load Washers
E01 and e06 codes
Washer will not do anything other than lock the door.
2 Related Answers
Anonymous
  • 166 Answers
SOURCE: Error message E06 on Whirlpool
Unplug the machine and wait 10 minutes before restarting it.
The system should reset!
FIRST before you restart it try the door when the plug is out!
If this does not remedy the situation you will need a hands on service call!
how old is the washer??
Let me know!
ngafm
Please give me a good rating before you sign off!
thank You!
Posted on Sep 06, 2008
ZJLimited
ZJ Limited
  • 17970 Answers
SOURCE: i get an f06 and
F6 code is an issue with the motor drive tachometer.
Most often this is caused by poor connections at the machine control or motor controller. Locate the main machine control by removing the top panel and the motor control by removing the rear panel. Remove each connector, one at time, and reinstall. If this does not work, you likely have a faulty control.
E1 means that the thermistor is open and needs to be replaced. The connections can be loose but the most likely cause of an E1 error is a bad thermistor.
If you're comfortable and confident in your do-it-yourself skills and have access to a volt/ohm meter you can check and replace this part yourself.
For replacement parts - head on over to SearsPartsDirect.com - PartSelect.com - or RepairClinic.com and enter in your full model number for a full parts listing.
Hope helps.
Posted on May 28, 2011
What does an E01 mean on a Defy washing machine
Defy washing machine E01 error
An E01 error code on a Defy washing machine typically indicates a problem with the door or lid. This could be caused by a malfunctioning door lock, a problem with the door seal, or an issue with the lid switch. The error code may also indicate that the door is not properly closed or that there is an issue with the wiring or connections related to the door or lid. It is recommended to check the door lock, door seal, lid switch, and wiring connections
Jan 21, 2023 • Dishwashers
My swan washing machine is showing e01. What is the problem
The E01 error code can indicate a problem with the water intake, the water temperature, or the door lock. First, check to make sure that the water intake is not blocked or kinked. If the water intake is clear, then check the water temperature setting. The water temperature should be set to the appropriate setting for the load. Finally, check the door lock to make sure that it is properly engaged and that the door is completely closed. If none of these steps resolves the E01 error code, then you may need to contact a professional to service the machine.
1helpful
Hyundai front loader. What does E07 error code indicate?
Error code E07 indicates that there is an issue with either the washing machines door lock or a problem the motor. In some washer models error code E01 will be displayed if there is a door lock fault problem.
What do error codes e06 and e01 mean?
E01 and e06 codes - Fixya
www.fixya.com/support/t14040885-e01_e06_codes
Aug 19, 2012 - e01 and e06 codes washer will not do anything other than lock the door. - Whirlpool Duet: WFW94HEXW Laundry : question. ... Error message E06 onWhirlpool. Unplug the machine and wait 10 minutes before restarting it.
2answers
Dish washer goes through cycle but when finished cold with Code E..09
Bosch Dishwasher Troubleshooting ' Dr. Dishwasher
www.drdishwasher.com/troubleshooting/manufacturer/bosch/
Your Bosch dishwasher can run a test cycle which will quickly go through each ... You can find a list of Bosch dishwasher error codes and their definitions here.
Pz 50hv2
If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/ Error code details to many brand TVs are given.
2helpful
E06 and E01 error code
E06
Paper output cover is open. Close the paper output cover.
Bosch vision error code E01 on washer
error code e01 means the computer thinks the door is open even when it's closed you can repair this using this guide:
Bosch Front Load Washer Error E01
5helpful
4answers
Error code E:01
Hi and welcome to Fixya, The E01 error for your bosch indicates a door lock problem has been detected at the control board. Insure the door is closed tight, turn your breaker off or unplug the washer for a couple of minutes and retry. Let me know what happens, ultimately it may be a faulty lock assembly, a loose wire harness etc. but we'll cross that bridge when we get there...if necessary. I'll watch for you to respond with the result's. Good luck. Macmarkus :)
1helpful
2answers
Light flashes green than a code E06 and E01 comes on than tv off
E01 is relay contacts failure on psu board in media box
Parksy HK
Now someone find E06
Marvin
Marvin
Mike
