Macromedia Flash 5.0 Logo
Posted on Jul 15, 2009
Flash language change
Hii
i downloaded flash 5.0 and i instlld it but wen i run it it was in some other language ..so i want it back in english so can ny1 help me out
1helpful
2answers
Facebook customer service
Hii Elsie,
To change your language on Facebook try the following steps:
  1. Click the small down arrow at the top right of a Facebook page and select Settings
  2. Click Edit to the right of the Language section
  3. Select your primary language from the dropdown menu and click Save Changes
Hope that helps!
3helpful
Change language from italian to english.. htc tyn II pro, thank you
Hi there!
You'll need to follow this steps to change the language of your HTC TyTN II
<p>1. Make sure you install Microsoft ActiveSync in your computer. Do a first time sync between your phone and the computer.</p><p> 2. Disable any screensaver and/or hibernation in your computer.</p><p> 3. Sync and again and flash with the HardSPL rom from OliNex. You can find this HardSPL software from here >> http://wiki.xda-developers.com/uploads/Unsigned_HardSPL_for_Blackstone_OliNex.zip The flashing completes in under 2 minutes.</p><p> 4. Reboot device. TouchFlo3D will launch into the native language the device originally came in. The new rom now enables you to flash other language roms, even official ones from HTC, bypassing licensing and verification checks (of course you should have the relevant ROM).</p><p> 5. Finally, flash again with the newset WWE (World Wide English ROM. You can download the official English ROM here: http://www.htc.com/hk-en/supportdownload.aspx?p_id=13&cat=2&dl_id=287</p><p> 6. Device reboots in english, or the language of the ROM you flashed.</p>
Take note that by doing this, the warranty of your phone will be voided.
Hope this helps
I need to change the language from arabic to english on my Acer Dx900
hii...
steps to change language from arabic to english.
1. goto start menu.
2 Setting > System > Regional Setting
22helpful
5answers
Language back to english
A. If it's the display language you need to change:
To change the text language:
  1. Touch the Wrench icon on the screen with the Magnifying Glass, Map and Brief Case icons
  2. Touch the Lips and Clock icon
  3. Touch the top bar next to the pencil with the letter A
  4. Touch the up arrow until you see American English*
  5. Touch American English
  6. Touch OK
The device should be in the selected text language.
*Note - If American English is not the language needed, please select the desired language.
B.If you need to change the voice language you need to change the voice:
  1. Touch the Tool icon
  2. Touch Locale
  3. Touch Voice
  4. Touch the Voice Language you would like to use
  5. Touch 'Ok'
  6. Touch and hold the Back button to return to the main "Where To" and "View Map" menu
At this time your device should speak in the language you have set in step 5.
C. It's possible you won't have an english language voice installed. IF not connect the satnav to your computer. Download the latest version of webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and install it on your computer. After it's installed you will get an option to download new voices. Select an english, american or any a voice from any english speaking country. When it's installed go back to para B and repeat to get an english voice selected.
1helpful
2answers
2answers
MY LAP TOP IS IN SPANICH IWANT IT IN ENGLISH
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} To change the whole system language you should install newer service pack with different language.
If you have XP SP2 in Spanish and want to have it in Eng, you will have to download SP3 in Eng, change someregistry keys (go to KEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\Nls\Language registry key, and then change the value date for “Default” and “InstallLanguage” registry value from 0409 to 0410) and you'll be able to install it in Eng.
Resume:
1.Go to start
2. Press run
3. Type Regedit
4. Go to HKEY_LOCAL_MACHINE\ go to "SYSTEM" \ go to "ControlSet001" \ go to "Control"\ go to "Nls" go to " languages"
5. Change the Default” and “InstallLanguage” (first and last in the list) to 0409 [for you.S english, for other codes look down in the thread],
6. Download and install Sp3 for xp in English
7. Restart computer.
8. Be happy for it works.
Thanks for using fixya…good luck and don’t forget to rate this…
cheers
1helpful
Changing languge
hii
go to settings and then the regional settings and there u select the regional language to English UK or English US....then directly soft reset ur phone i meand restart it and enjoy with english language if u find any problem do contact me
1helpful
Would like to change Language settings for Epson Stylus Photo R290 Series Printer... Currently when printing a Test and when I go to the Print Preference, its showing as a foreign language... How can...
1. First of all, you must completely uninstall your current driver (with foreign language).
2. Download Epson R290 English Language Driver from here :
http://www.epson.com.sg/epson/drivers/driver_download.htm?dc=1&mode=3&mfalse&catid=1&pid=1259
3. Unplug your printer USB Cable from your PC
4. Run : Setup.exe
5. Follow the instruction, and thats it. You've English Language now :)
I have tried this and it worked :)
Top Macromedia Computers & Internet Experts
ExpressFiX
ExpressFiX
Rob Hill
Rob Hill
Are you a Macromedia Computer and Internet Expert? Answer questions, earn points and help others
