Windows 10 64-bit, HP Universal Printing PCL 6 driver. Printer status notification is enabled in the driver.
Check your cables. Try turning the printer off and leave it turned off for 5-10 minutes, disconnect all the cables, restart the PC. Plug the cables back and turn the printer on. What does the user manual say? Download Free Manuals
SOURCE: HP4000 not printing LPT1
Dear sir;I believe you can try " cold reset", that's means going to clear all data from the printer memory and sets all the defaults back to the factory settings.performing a "cold reset" resets the jetDireect configuraion. to avoid making changes to yourconfiguration, remove the jetDirect card before performing a cold reset. if possible, print a configuration page prior to performing a cold reset. this will document current settings for later reference.
to perform a cold reset;
1, turn off the printer.
2, while pressing "go", turn the printer on. COLD RESET appears briefly on the display, then INITIALIZING appears.after a few seconds, RESTORING FACTORY SETTING appears on the display, followed by OFFLINE.the cold reset is complete.
3, press "go" to return the printer online "ready " appearson the display.
Little bit complicated but is easy ,hope can take care your problem, GOOD LUCK! Let me know the resolve please!
HAVE A HAPPY HOLIDAY !!!
SOURCE: Laserjet 1022n and Universal Print Driver
i solved this problem in my case with an compatilble standard driver from windows. An PCL Laserjet 5 / Laserjet 6 Driver.
And no problems occour.
On the clients and the server all iss fine.
SOURCE: the printer keeps printing in landscape form even
This sounds like a software problem...
Try using the PCL5e driver instead.
SOURCE: the Windows 7 driver for the HP deskjet5650 does
Driver download link: HP Deskjet 5650 Color Inkjet Printer Driver
SOURCE: Cannot install HP Deskjet 3745
Open the Devices and Printers folder
Right click on the Printer icon and Click on Troubleshoot
Follow the instructions and finish the Troubleshooter Wizard
You should be able to print
Another quick fix for most communication errors can be
achieved by resetting the printer and/or rebooting the PC. Simply disconnect
the printer from your computer. Reboot your pc. Unplug and re-plug the printer
into the power source to reset it. When the printer turns on, reconnect it to
your computer. Then try to print again once the computer fully recognizes the
USB connection.
I hope this helps.
