Freezer door does not close securely. It wants to pop open easily.
SOURCE: freezer door won't stay shut
Could be the air pressure created from shutting the refer door is popping open the other one. There are are channels between the two so cool air from the freezer gets to the refer compartment. Try this as a test... s l o w l y close the refer door and see if that keeps the other door from popping open. If that works then it's likely an air channel is frozen up somewhere and you may need to turn the unit off for a day or so to let it thaw out. Moisture from leaking door seals, or doors that were left slightly open overnight can be sucked in and freeze up the air channels. I don't know if you are sort of slamming the door shut or not but the doors need to be shut slowly due to how air tight the new refers are.
SOURCE: EB22BRXU
My E521 does this too - it's because there is an air duct between the 2 compartments. That duct allows the fans to move air about.
I agree you'd think the freezer should remain shut at all times unless you really need to be in there
SOURCE: Freezer door pops open.
normal operation actually, gaskets are designed to seal door closed not to hold them closed, first off check the items on the shelves make sure nothing stick to far out preventing good closing.next the refrig should be tilted slightly back. to aid in the doors swinging closed( the should close automatically form 45 degrees.)ok for them to "pop" open so long as they close back shut. this works on top freezers and bottomr freezer refigs, sidex sides use a differnet system of closing, if htats the case look into replacing door closures(cams) located under hte door assy
This indicates that you do not have good airflow and return airflow between your freezer and refrigerator sections. That is why the pressure from closing one door is causing the other one to pop open.
Check the drain tube on the back of the machine to make sure it is not clogged or blocked with frozen water inside. Also check any return air flow vents inside the unit for clear ice.
SOURCE: freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
