PDF]PW80T Owner's Service Manual - Yamaha
www.yamaha-motor.com/.../lit-11626-18-30_108...
Yamaha Motor Company1st Edition, April 2004. All rights reserved. ... GINNING RIDER. DO NOT REMOVETHESE ITEMS UNTIL THE ADULT SUPER- ... may leak out of the carburetor or fuel tank. 5. ... Removal of this plate adds to the ..... side of the engine on top of the crankcase. 1. .... Throttle Check for proper throttle cable operation 5, 12. Air filter ...
Yamaha PW 50 checking carb - YouTube
? 3:03
https://www.youtube.com/watch?v=M5Pe6YH6l3c
Apr 18, 2012 - Uploaded by fupabox
Checking out the slider,choke,and fuel flow on a 2002 Yamaha PW 50 ... Top comments ... the idle speed adjustment is either too low or the carb is gummed up...with it ... get full throtle and it just boggs any suggestions on what i shud do ... Yamaha PW 80- First Start in Years - Duration: 7:26. by Alex's Bikes ...
How to clean a pw carb - YouTube
The front choke on a motorcycle is typically used to help start the engine by enriching the fuel mixture when the engine is cold. The choke is usually controlled by a lever or button located near the throttle, and is typically only needed when starting the engine from a cold state.
To connect the front choke on a 2000 Suzuki Intruder 1400, you will need to locate the choke cable and follow it to the carburetor or throttle body. The choke cable will typically have a small lever or plunger at the carburetor end, which is connected to the choke mechanism inside the carburetor or throttle body.
To connect the choke cable, you will need to attach one end of the cable to the lever or button near the throttle, and the other end to the lever or plunger at the carburetor end. Make sure the cable is properly seated in the levers or plungers and can move freely.
It's important to note that every motorcycle is different, and the specific choke mechanism on a 2000 Suzuki Intruder 1400 may differ from the general information I have provided. If you are having difficulty connecting the choke on your motorcycle, it is always best to consult a service manual or a wiring diagram specific to your make and model.
