HP color laserjet enterprise cp4525 display error 49.2FA7
Try this link might help you out... HP color laserjet enterprise cp4525 display error 49 2FA7 Google Search
SOURCE: Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
SOURCE: HP Printer Color LaserJet 2840
I Have A HP Laserjet 2820 on power up went through to scanner bulb warming up then made a clicking noise comming from scanner unit it was trying to escape the case. if this is the same as yours the problem is that the scanner unit can't find the home position strip mounted betweent the gray case wide piece right hand side as you look down on scanner unit with lid up & the top of the scanner glass inside the scanner unit to get to it you must remove top section of the scanner unit & cleean underside of scanner glass please E-mail me if you want full instruction.
SOURCE: how to clean a density sensor unit on a hp color laserjet 8550
1 Open the right upper door.
Sensor is located on the door lower center of door ther should be a small brush next to it
2 Use the brush located next to the sensor to remove all toner
particles from the sensor.
SOURCE: MY HP LASERJET 3005 DISPLAY ERROR 49.2F9D
Its already discussed in one of the forums for Hp.
check :-
https://forums11.itrc.hp.com/service/forums/questionanswer.do?threadId=1158526
Thanks
SOURCE: Hp laserjet M2727nf scanner error 52
First, power the printer off, wait for about 30secs and power on. If problem persist replace the scanner.
