Sharp no longer makes this bake element. So, the part store set me up with a 3000 watt, Electrolux bake element. Remarkably, it is the same size and specification as the OEM. Now, I am getting this error message. I checked the temp. sensor, and it is fine.
SOURCE: Sharp AL 1631 Grayscale Copier Problem
Have you tried removing all cable connections on it and turning printer off and unplugging it from power supply and powercycle?
SOURCE: Sharp Z-835 Copier with H3 error code. I
Hello sir; It don't need to anything but reset, the procedure as follow; press "clear" 'exposure" "clear" "exposure" then press 14 hit print, it should take care of you, good luck.
SOURCE: Sharp Carousel micro/convection, sparking and says "sensor error"
Hi! try checking the capacitor.
