SOURCE: Reverse Firmware Upgrade
http://www.fixyourownprinter.com/forums/printer/56368
There are two different print engines used in the CLP-300. One for
2006, and a different one starting in 2007. I have the older 2006
printer, and the current firmware is only for the new 2007+ print
engine.
I talked to Samsung support here in Korea and fixed the
problem. They sent me to their special tech support website at
www.1479.co.kr (only in Korean) and I was able to download an older
version of the firmware which restored my printing ability.
The latest version of firmware that worked with my printer was found in this post: http://www.bassmania.co.kr
Download
the two files at the top, then extract the archive. Drag-n-drop the
correct firmware file onto "usblist2.exe" and the printer will be
flashed with the firmware (must be connected via USB if you're using
the CLP-300N model).
SOURCE: received email from kodak informing of software
you will have to uninstall and reinstall the software so run the clear utility to uninstall the software from www.kodak.com/go/clear and unplug the USB cable for the printer and then reinstall the latest software from www.kodak.com/go/downloads ........also try and use the printer in standalone mode that is try and copy something and check there is no hardware issue.........coz if it does not copy then it could be a hardware issue......let me know if this was helpful...........
