Cars & Trucks Logo
m
mandla mabuza Posted on Sep 07, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My engine is vibrating and loss power
Even when is hot is vibrating its running and some as if is misfiring
chrisheman
Level 2:
Novelist:
  • Expert 145 Answers
  • Posted on Sep 07, 2015
chrisheman
Expert
Level 2:
Novelist:
Answers
145
Questions
Helped
50013
Points
411
Most common fault is one of the spark plugs is "dead' (not sparking any more). As first order check if the spark plug wires are properly connected (plugged in) to the spark plugs. Try to isolate the 'dead" spark plug by disconnecting only one spark plug wire from a spark plug at a time (Leave the others connected) and try to start the car. If it is not the dead spark plug the car will not start as it will have now two dead spark plugs. Reconnect and disconnect the next spark plug. Continue until the car start running badly as you experienced it before the test - you have found the culprit. Replace it, however replace all the spark plugs and your problem might be solved without this test procedure.
Bill Boyd
Level 3:
Top Expert:
  • Cars & Trucks Master 53,816 Answers
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11950475
Points
172802
Run the fault codes and find the reasons
2answers
Where is the transmission mount located?
Under the transmission under the car.
Engine misfires at high rpm no code
Bad ignition coils will make the truck act like this. Also low fuel pressure.
2003 gmc jimmy on hills loses power check engine blinks then stalls upon restart performs great runs well on flats and even not steep hills .
when engine light blink it is only one thing.......misfire you could have P0300,P0301 and so on
P0300 is multiple misfire
P0301 is cylinder no 1 misfire,the last number tell you the no cylinder
hope it helps
Spark jumping from coil pack causing the engine to miss
Hi there:
Misfire is a common driveability problem that may or may not be easy to diagnose, depending on the cause. A misfiring cylinder in a four-cylinder engine is, pardon the pun, hard to miss. The loss of 25 percent of the engine power output is the equivalent of a horse trying to run on three legs. The engine may shake so badly at idle that it causes vibrations that can be felt in the steering wheel and throughout the vehicle.
Basically, it's one of three things: loss of spark; the air/fuel mixture is too far out of balance to ignite; or loss of compression. Loss of spark includes anything that prevents coil voltage from jumping the electrode gap at the end of the spark plug. Causes include worn, fouled or damaged spark plugs, bad spark plug wires or even a cracked distributor cap. A weak coil or excessive rotor gas inside a distributor would affect all cylinders, not just a single cylinder.
Lean misfire can occur when the air/fuel mixture is too lean (not enough gasoline in the mixture) to burn. This can be caused by a dirty, clogged or inoperative fuel injector; air leaks; or low fuel pressure because of a weak pump, restricted filter or leaky pressure regulator. Low fuel pressure would affect all cylinders rather than an individual cylinder, as would most air leaks. A leaky EGR valve can also have the same effect as an air leak. In fact, if a vehicle has one or more misfire codes and a P0401 EGR code, the fault is likely carbon buildup under the EGR valve.
Loss of compression means the cylinder loses most of its air/fuel mixture before it can be ignited. The most likely causes here are a leaky (burned) exhaust valve or a blown head gasket. If two adjacent cylinders are misfiring, it's likely the head gasket between them has failed. Also, if an engine is overheating or losing coolant, it's likely the head gasket is the culprit.
Intermittent misfires are the worst kind to diagnose because the misfire comes and goes depending on engine load or operating conditions. They seem to occur for no apparent reason. The engine may only misfire and run rough when cold but then smooth out as it warms up. Or, it may start and idle fine but then misfire or hesitate when it comes under load. Also, it may run fine most of the time but suddenly misfire or cut out for no apparent reason.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
98 ford mustang spark jumping from coil pack
Hi there:
1helpful
2answers
Hi there:
1helpful
I am experiencing power loss from my 2.0tdi 140 A4. seems like massive turbo lag. Started with juddering at low revs in 1st & 2nd gear, then complete loss of power. Starts ok & idles but no pulling...
these vehicles are known for ignition coil failure. typical symptoms include: Misfire, power loss, vibrating engine, poor fuel consumption. If the vehicle's engine vibrates, it be misfiring. Is your chk engine light on???
3helpful
I am having ongoing problems with the truck miss firing and rough running. Timing is ok, replaced cap and rotor,coil. It still starts rough,idles rough and misses when at cruising speed,although it seems...
Misfire is a common driveability problem that may or may not be easy to diagnose, depending on the cause. A misfiring cylinder in a four-cylinder engine is, pardon the pun, hard to miss. The loss of 25% of the engine's power output is the equivalent of a horse trying to run on three legs. The engine may shake so badly at idle that it causes vibrations that can be felt in the steering wheel and throughout the vehicle. The engine also may be hard to start and may even stall at idle, depending on the accessory load (air conditioning, headlights and electric rear defroster, for example).
When misfire occurs, performance suffers along with fuel economy, emissions and idle quality. And, when a misfiring vehicle is subjected to an emissions test, it will usually fail because of the unusually high levels of hydrocarbons (HC) in the exhaust.
What causes a cylinder to misfire? Basically, it's one of three things: loss of spark; the air/fuel mixture is too far out of balance to ignite; or loss of compression. Loss of spark includes anything that prevents coil voltage from jumping the electrode gap at the end of the spark plug. Causes include worn, fouled or damaged spark plugs, bad spark plug wires or even a cracked distributor cap. A weak coil or excessive rotor gas inside a distributor would affect all cylinders, not just a single cylinder.
"Lean misfire" can occur when the air/fuel mixture is too lean (not enough gasoline in the mixture) to burn. This can be caused by a dirty, clogged or inoperative fuel injector; air leaks; or low fuel pressure because of a weak pump, restricted filter or leaky pressure regulator. Low fuel pressure would affect all cylinders rather than an individual cylinder, as would most air leaks. A leaky EGR valve can also have the same effect as an air leak.
Intermittent misfires are the worst kind to diagnose because the misfire comes and goes depending on engine load or operating conditions. They seem to occur for no apparent reason. The engine may only misfire and run rough when cold but then smooth out as it warms up. Or, it may start and idle fine but then misfire or hesitate when it comes under load. Also, it may run fine most of the time but suddenly misfire or cut out for no apparent reason. Intermittent misfires can be a real challenge to diagnose, so let's start with a steady misfire in one cylinder before moving on to intermittent misfires.
Hope this help.
3helpful
2answers
Check engine light stays and blinks on a 2005 pontiac grand prix gtp and it also has vibrations as u drive
Sounds like it is misfiring.
Try changing the spark plugs and you MUST run premium fuel.
Engine misfires, power loss when warm and under load
What grade of you do you have ? must be 5/30 fully synth or it breaks down when hot and makes for a misfire.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
