Ribbon cable issue found with this device. look inside at the white ribbon cable. The cable likes to bunch in bewtween the spinning hub and the eye assembly, after time it may even develope a rub spot that will shut you down for good. If the cable is bunched up, try pushing it back into the bottom of the device and try again.
My dvd it keep saying no disk ans it wont spin what do you think is the problem and how I fix it
Make sure there are no finger prints on the disk the portable units are very sensative to dirt and grease like finger prints try cleaning every thing,
It says that its loading then it just stops by itself or says error disk
My 7" DVD Player (PDV-705 by Durabrand) just keeps "loading the disc" when I put one in...it continously spins. I can not use any controls like STOP, PLAY, or anything else. The odd time I can finally get it to stop loading and I press play it will not let me do anything...it says STOP whenever I press PLAY.
I have a Durabrand 7 inch dvd player the model number is pdv-705 when i try to watch dvd it says it is loading then it stops and it say erro disc it will not play can you help me are tell me what is the problem?
my disc just spinns im getting ready to clean the eye and lube up the tracks but when the disk spins the eye dosent even move at all it use to every time i change diskes ............
Every time I put a dvd in this player the disc spins and stops. Then the screen says err disc or no disc. whats up with that this product sucks!!!
I have the same problem.....when I load a disk it spins and spins (seems noisy, too) then says ERR DISC and NO DISC. I have tried cleaning the disc (happens with any disc anyway) and tried a cleaning disc in the player, but it doesn't make a difference. It won't even recognize the cleaning disc.
Any suggestions?
The dvd will start loading and stop and will not play dvd.
My dvd-705 will spin and spin and says it is loading but then stops and won't play the dvd
my dvd says no disk and it wont spin either
Same Problem. will work on occasion. What do we do? Frank [email protected]
