Garden Logo
d
dan myers Posted on Jul 29, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PTO turns with mwoer shaft disengaged, blades turn when shaft is rotated by hand. Put shaft into PTO housing and the mower wont turn.
jamiesmiles
Level 2:
Habit-Forming:
New Friend:
  • Expert 104 Answers
  • Posted on Aug 07, 2015
jamiesmiles
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
104
Questions
19
Helped
41093
Points
183
Bad pto, 400 dollar to fix but a cheap option is to replace the pto switch in the dash first, is the pto switch clicking with the key in the ON position? if it is then it is the pto clutch bad
John Deere eztrak mower went over a rock today and now the mower won't engage
hmm strange are the belts driving the blades ok if so then the PTO could be damaged but if there's no sign of damage it maybe a bit frozen up/locked up have the engien off but turn the key on and engage the PTO switch and manually turn the PTO (not by the blades please....dont want to have your hand taken off) turn by the PTO itself and if you hear any clicking sound disengage the PTO and engage a few times to ensure your hearing the clicking sound of the PTO turning on and off and it should be back to normal also check any connections going to the PTO before doing the manual work of repairing the PTO
1helpful
I have a 52" Husqvarna LGT 2654 riding lawn mower and when I engage the blades, the belt does not turn the pulley system. What could be causing this, the pulley idlers, or the belt?
depending on the age of the machine, there could be several possibilities
1-- belts are not tight enough--- belt tension system is not correct, wrong length belts
2--bearings for the shafts for the blades are rusted up and seized - preventing the blades from moving--- switch the machine off , disengage the belt drive and see if you can turn the blades by hand
3--- if you have an electric pto system to drive the belts to the blades then that system is not getting full power to engage the PTO or the clutch is not working--worn facings
take it to a service dealer and have a proper diagnosis done
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 • Troy Garden
PTO turns without mower shaft inserted. Mower blades turn when rotating shaft by hand. Slide shaft back into PTO and nothing is turning. Belts on mower deck look ok.
Sounds like your magnetic clutch is not fully engaged or slipping and cannot handle the load of the mower deck..try this...Using a good pair of snug fitting gloves..with the engine in its lowest idle position and the shaft out of the clutch turn on the clutch..now carefully see if you can manually stall ( make the clutch slip) if it does sip or stall it needs replaced.just be careful....good luck..
Jul 29, 2015 • Garden
1helpful
On my 42in cut hydro. Husqvarna, The mower will not disengage until the speed is reduced to a low idle
Before you do anything else check to make sure the blades are engaged on thier seat ( the star) and the blade bolts are tight.
If you have an electric PTO this does not apply to you.
After confirming that your blades are tight check the operation of the PTO cable and the pivot bracket by lowering the deck all the way. Laying on the ground on the discharge side of the mower you will be able to look at the components and see and touch whats not moving freely as you engage and disengage the PTO lever. Look for a stiff PTO cable, stiff pivot bracket, missing return spring, broken spindle brackets and broken deck bracket welds.
Of course you should never work on any mechanical device while it is running.
PTO not working
You have snapped the shear pin that is in the drive pulley. You have to remove the pulley that spins on it's shaft off and put a new shear pin into it. I have replaced several myself. The shear pin is a protection to prevent costly breaks.
Nov 12, 2017 • Garden
Pto will not disengage
first unplug the switch and see if it still operate then disconnect the spark plugs then turn the blades threw the discharge opening and see if the engine rotates when moving the blades this will tell you if the clutch is stuck then connect the spark plug wires back on and next to the engine base you will find a 2 wire connector that feeds the clutch power and ground unplug that connector and start the mower see if the blades turn this will tell you if you have a mechanical failure if it does not operate with the wires unplugged its a electrical
John deere stx 38 with black deck, will not do anything, tested with ohm meter, get 12.83 volts from battery , get 12 volt to solenoid when turn key on, can start if i jump battery to solenoid, but mower...
I see this problem not as an electrical but a seize problem. Since I can't be there to inspect I am relying on your discription of the problem. I would go first to the place of the problem. If this solenoid goes up to disengage and down to engage ,or the opposite, this is most likely your problem area. It may be seized in the disengaged position therefore not allowing the blades to get spinning. Disconnect the belt and try to turn unit by hand, if tight or completely stuck use penetrating oil on pulley shaft.If shaft loosens up and blades engage this was the problem. Is there a grease fitting anywhere in the area?I hope this at least gets you started in the right direction. GOOD LUCK.
9helpful
2answers
The mower deck on our Cub Cadet RZT 50 mower stopped working while mowing. We have cycled the PTO switch several times with no change. The belt is in place and the mower blades rotate freely by hand. The...
You can check the clutch by taking a wire from the ground and a wire from the positive side of the battery and energizing the clutch directly with the belt off to see if thats it. It could simply be a wire loose in the connection on the clutch....their soldered on.
Top Garden Experts
Jay Finke
Jay Finke
john h
Thomas Perkins
Thomas Perkins
