Cars & Trucks Logo
A
Anonymous Posted on Jul 27, 2015
Price to replace oil pump on 98 gmc sonoma 2.2l 5speed truck. Also what else is a good idea or has to be replaced while this job is done. Truck only gets about 5 pounds oil pressure after started
  • Anonymous Mar 11, 2016
    Ended up replacing engine . the oil pump was bad causing engine too much damage due to previous owner
Darci Goodman
Level 2:
New Friend:
  • Expert 77 Answers
  • Posted on Jul 27, 2015
Darci Goodman
Expert
Level 2:
New Friend:
Answers
77
Questions
0
Helped
31260
Points
212
There are a number of things that contribute to oil pressure, the pump has very little to do with pressure. I will say I have seen a lot of issues with the pick up screen inside the oil pan becoming clogged. I would suggest hooking up a manual gauge to verify actual oil pressure, then if it is actually low I would remove the oil pan and check the pick up screen first. You're looking at 11-12 hours labor at a repair shop plus 100-150 for the pump if you want it replaced. Plus gaskets and oil.
5 Related Answers
Fahr Quad
  • 776 Answers
  • Posted on Feb 26, 2009
SOURCE: '97 Dodge Dakota 5.2l oil pressure problems
On the 318 (5.2 liter) V-8 that was in my 1973 Dodge Dart Sport, I started having oil pressure problems with valve ticking and clunking around the crankshaft around 173,000 miles. Prior to the problem, I had bought a couple cases of Pennzoil on sale. Needless to say, when I finally dropped the pan, the sludge had baked to a ceramic-like texture. I soaked the pick up screen in solvent to disolve the crud, replaced the oil pump, and replaced the main and rod bearings with undersized bearings (.001" undersized). The oil pressure went up to normal, the valve tick went away, and the clunking on the bottom end went away. The engine felt as tight like new, and should have lasted for another 150,000+ miles if the nitwit I sold it to hadn't wrapped it around a light pole. By the way, don't ever use no-name, Pennzoil or Quaker State motor oil. The minimal savings will cost you in the long run.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Sep 06, 2009
SOURCE: OIL PRESSURE SWITCH CHEVROLET 4.3 1994 SONOMA /S 10
hook up a mechanical gauge and verify the pressure at idle is correct, I suspect the sending unit is defective
batviper
Steven Burke
  • 120 Answers
  • Posted on Nov 18, 2009
SOURCE: 1995 s10 pickup 4wd just replaced fuel pump, won't start.
replace the wireing harnes to the fuel pump gm had problems with them cost around $15 to 26 at autozone
Anonymous
  • 5 Answers
  • Posted on Feb 06, 2010
SOURCE: i have a 98 gmc sonoma 2.2L and i was driving down
check the fuel pump relay its probably shot you should be able to hear it click swap it out with one of the others cheap fix
Anonymous
  • 10 Answers
  • Posted on Jan 23, 2011
SOURCE: 1992 GMC Sonoma 4.3 V-6 The
did u check to see if u were actually gettin fuel..ur filter might b clogged..and did u replace the button along with the cap and rotor..and did u check to make sure u got spark..it might b the coil..they go without any warning
How do I remove oil pan on a 2001 gmc Sonoma pick up truck to replace gasket
1993 GMC SONOMA 2.6 CYL V6 NOT 4x4 OIL PAN ...
? 2:31
https://www.youtube.com/watch?v=1KsRTlnW7Cg
Sep 27, 2011 - Uploaded by JohnSmiths8379858
trying to reomove the oil pan to this truck has been sitting for about 6 ... 1993 GMC SONOMA 2.6 CYL V6 NOT 4x4 OIL PAN REMOVAL "HELP!
Oil Pan Gasket: How to Change Oil Pan Gasket for 2001 ...
www.2carpros.com/questions/2001-gmc-sonoma-oil-pan-gasket
Mar 18, 2011 - How to change oil pan gasket for 2001 sonoma, can i get away with just raising the engine two inches to ... 2001 GMC Sonoma • 4 cylinder 2WD Automatic • 150,000 miles ... You need to remove the engine to get the sump off.
97 sonoma only runs on starter fluid
if it ran fine before this happened then check the fuel pump relay first. it may have shorted out when jumped off, or when battery was replaced
Whate type of fluid does a 1991 gmc sanoma 2.8 liter 5 speed take for transmission
i have a 1992 gmc sonoma with a 2.8liter engine with a 5speed manual trans. does it uses atf or gear oil if it uses atf what kind?
1997 GMC Sonoma with 4 cyl engine. The truck runs great, but after the engine warms up, the oil pressure drops to around 12 from 50 when cold. is this the oil pump and how do i change?
Depending on oil type (IE: synthetic, etc) this is normal. If using conventional oil then I'd be concerned. To replace oil pump you'll need to remove pan and it is bolted to lower part of engine.
My 2002 gmc sonoma (extended cab sls) will not start i have changed plugs and wires fuel pump and fuel filter i have done oil change and air filter change. the truck will fire if i give it a spray off...
My engine light in my 2002 GMC Sonoma has been on for the past four weeks. Yesterday I had an oil change done on my truck with a local mechanic. He turned the engine light off, but it came on soon after leaving his shop.
This morning I went to start my truck and there was NO power whatsoever. After repeatedly turning the key, I soon saw a slight movement on the battery display, but no lights would come on. It just seemed like it wasn't getting any power. I changed the battery two years ago, so it should be fine.
Eventually, the truck received full power and started, more less out of no where. It wouldn't hold an idle and would just die if i took my foot off the gas.
Hopefully someone has a solution for me.
Thanks.
1helpful
Have a 98 gmc sonoma. Clutch does not have much pull but yet does not slip. I cannot get the clutch and gas timing right because the truck boggs down a bit comming out of 1st
either its time for a clutch job or you have a hydrolic slave cylinder issue. the fluid could be real low, you could have air in the system.
2answers
Fuel pump problem
replace the fuel pump relay. in the underhood fuse/relay box in front of the master cylinder.
Driveing and truck stoped running,,replaced fuelpump and filter,,got a bad pump and replaced it again,,truck would still not start so I checked spark,,,had a bad cap due to ear on desterbitor...
check to see if you're getting spark from coil into distrubitor. if you replaced al those, the only thing i can think is it's the coil.
6helpful
4answers
The heater still won't work after I changed the thermostat on my
Get a female garden hose adapter from the local hardware store. Disconnect the heater hose from behind the fan pulley and attach the hose connection. Disconnect the other heater hose behind the alternator, aim it towards the ground and flush water through the heater core. This worked on my truck.
Top GMC Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a GMC Expert? Answer questions, earn points and help others
