2003 Harley Davidson FLHTCUI Electra Glide Ultra Classic Logo
Posted on Jul 12, 2009
I have static comming through the speakers on my 03 ultra
Anonymous
Level 1:
  • Contributor 50 Answers
  • Posted on Jul 14, 2009
Anonymous
Contributor
Level 1:
Answers
50
Questions
0
Helped
25938
Points
82
Have you changed the plug wires on bike recently? If so were they of the proper resistance? If not , then I would start by having the plug wires changed. Plug wires that have bleed through can cause this problem
1helpful
My Roland KR-03 Piano has bad static sound on the left speaker. It is also in the headphones.
seems to me this will need more than most people can do. tracking down the problem will require a lot of testing of transistors and such... but just maybe it's nothing more than a loose ground wire on the circuit that powers that side. Good luck.
Lincoln town car 03 & 05 CD player works radio shows station but no sound
are you speakers blown? is it stock? do you get any static at all?
My radio and cd want put no sound out fuses are ok and my speaker is makind nose even when the car is turn off
'03 G35 Radio Problem. Speaker Noise Even When RadioTurned Off ...
g35driver.com/.../437164-03-g35-radio-problem-speaker-noise-even-w...
Feb 1, 2014 - Turned entire car off/on several times, no change. ... Still had the static/crackling type noise from driver rear speaker at all times - even with ...
1helpful
2answers
Where is the signal flasher located on an 03 ultra classic
On an 03 bagger it will be under the seat. You'll have to remove it. Under the seat is the battery you should see a little silver clip towards the back ledge of the battery tray. That's the turn signal module. Remove the clip and pull the unit up amd out.
Installing a Harmon Kardon on a 03 Ultra
The 23 pin main connector is a direct plug in from the 03 bike to the HK unit. The only issue would be if the original 03 was using the accessory connector as well. The accessory connector on the 03 is another 23 pin. It's a 35 pin on the HK. For more info, or to discuss this further, contact Iron Cross Audio (www.ironcrossaudio.com)
1helpful
Ultra mp3 lience key
HI,
You might wanna download the complete package from here with licence.
http://www.mobileboss.net/2008/03/03/ultramp3-152/
Thanks.
Echo suppression
I don't know how to remove the echos from you video but think I know what is causing them.
Normal 0 Two things can cause static.
First, If you have your speakers turned up to high it will give you feedback causing distortion and static. I'd use headphones during videoing.
Second reason is, if you are using a laptop and have added an external microphone between the two it will cause distortion and static.
Not knowing the configuration of your computer makes it harder to analyze the problem.
So hope this is of some help. Bud
Top Harley Davidson Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
ZJ Limited
ZJ Limited
Are you a Harley Davidson Expert? Answer questions, earn points and help others
