Hi ! for an informantion, please visit the website below. If you need more information about a specific electrical issue you can reach me at [email protected].
Motor Part Store Motor Parts Wholesale
SOURCE: 1997 Royal Star Tour Deluxe
your switch has gotten water in it, under the tumblers the connecters have been arking & caroading causing it to loose connection
SOURCE: How do I add coolant to my 2005 Yamaha Royal Star
remove radiator cap slowly pour in 50/50 mixture while burping radiator hose. Better to do while running if possible
SOURCE: how do I check the oil level on a 2005 yamaha
What would happen if I need to get more roaring & louder sound from my original stock exhausts by drilling 1 hole in each exhaust end
SOURCE: 2007 Royal Star Tour Delux with 15,000 miles. Rear brakes scored
Not an unusual problem, no recalls. Replace pads (and rotor, if necessary), but after brakes are bled, loosen the bolt between the rear caliper arm and the swing arm, have someone apply and hold rear brake, tighten bolt. The arm, which holds the caliper in line with the rotor, occasionally loosens and allows misalignment. Checking pad thickness on both sides of the disk regularly will reveal caliper problems if wear is not evenly distributed.
SOURCE: Is there a way to hook up 4 way/emergency flashers
Not without seriously compromising the wiring harness and exposing wires to excessive corrosion. The turn indicator circuit starts at the signal fuse, voltage goes from the fuse to the flasher relay, through the relay to the turn indicator switch. The switch has a single input (voltage from the flasher) that may be routed by the switch one of two directions - the two left turn indicator lights OR the two right turn indicator lights, There is no position that routes voltage to both sets of lights, nor is there a provision in either the switch OR the wiring harness for one to be created. Police motorcycles have special wiring harnesses that intercept the leads between the switch and the lights, diode-protecting the turn indicator switch from voltages generated by a separate light control box, used to power flashing lights added during the assembly of the motorcycle, or by qualified installers during its conversion for police use.
