SOURCE: Kenmore dryer...How to remove toe panel to clean lint out.
Insert a putty knife into the seam where it meets the front panel about 2 inches in from each side. There is a small retainer clip that you will need top depress in order for the panel to release. If you go to searspartsdirect.com and enter your model number, you can find a helpful illustration under the "Cabinet" heading. The clips I mention are listed as item 46 just ot give you a perspective. I would also strongly recommend that you UNPLUG the dryer before cleaning the interior cabinet. There are live voltages present even with the dryer turned off. Particulary around the heating circuits. I hope you find this information helpful.
SOURCE: how to remove lint tray receiver: maytag dryer model#pye2300ayw
Unplug first with a straight blade screwdriver, pry up on the top of the dryer where the front wall of the dryer and the top meet. there are 2 screws 1 on each side inside the dryer where the sides and front meet, remove them and unhook the wires from the door switch. the whole front will now pull out and up, now open the door remove the 2 screws at the bottom of the door opening and the whole lint tray will pull out. sounds like a lot but only takes about 5 minutes.
SOURCE: Frigidaire electric dryer; model # FDEB34RGS1- gets TOO hot!
I could not find the model number you listed. I also would be very concerned about over heating until we can find and locate the problem. Look inside the door and compare number with the on listed here at Fixya. Thanks, Sea Breeze
SOURCE: F @ P DEGX2 lint trap problem
If you are collecting more on the outside of the house means the lint filter has a tear in it and the lint in being pulled through the tear and pushed out the exhaust. It sounds like you need a new filter but this isn't cheap. If you do it your self it will run about $70 if you get a repair man it will cost about $150.
