E20 error code: Short or break causing incorrect resistance in winding of the circulation pump or the motor.
D10 error code: Cause: Wiring/electrical fault related to motor triac.
Action: Check wiring on/to PCB and motor. Check the triac (on the PCB).
C01 error code: Cause: Motor tacho fault.
Action: Check motor and motor tacho wiring for problems.
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
E20 is a general error code to get to the real problem try this..
Reading Error Codes
1. Wake the washer by pressing any button.
2. Wait 5 seconds.
3. Press and hold the START/PAUSE and CANCEL
buttons simultaneously. As long as the buttons are
held, the failure code will appear in the display as
an “E” followed by two numbers, a number and a
letter or two letters. The control will beep and the
Door Lock, Wash, Rinse, and Final Spin indicator
lights will flash. let me know what code come up... hope it helps
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.
I also got the error code E20 when the filter became totally blocked during the washing cycle (due to a pair of my son's old work jeans!). Once I cleaned out the filter everything worked ok again. Put a large bowl under the filter as you unscrew it; a fair amount of water could be there.
Regards,
John
