SOURCE: ACER Travel Mate 5520
it could be a vga driver fault check the driver in device manager.
if the device can not start, uninstall the driver and reinstall.
ONLY DO THIS IF YOU HAVE THE ORIGINAL DRIVERS!
SOURCE: acer travel mate 230 laptop
is it completely black or very dark screen ?
if it is completely black, try to reseat memory first, if this is not working, it's look like your motherboard or cpu have problem.
If it is dark screen, it might be your lcd inverter is bad.
SOURCE: i need all dreiver acer travel mate 23oo
Here is the driver download page.
Remember to leave proper feedback.
Many thanks.
SOURCE: acer travel mate 2700 black screen of death
Hi
It maybe that the invertor or the backlight has gone on the unit and you can either try replacing the screen or invertor yourself or take it to a reputable computer shop and ask them. If its the screen they tend to charge around £140 to resolve.
Taz
SOURCE: ACER TRAVEL MATE 2480 WILL POWER ON BUT SCREEN REMAINS BLANK.
look close to the screen and see if there is a faint picture. if there is then read below for the issues and solutions that can cause this problem.
Issue 1: Lid button sticking
this is a common issue with this model that the lid button sticks closed. fiddle with it to see if it opens and the light comes on.
issue 2: Inverter for the monitor is bad
this is not to uncommon an issue when this problems shows itself. Laptops monitors light up with a fluorescent bulb. This is powered by an inverter. These can go bad and if they do the light will not turn on. you need to take this to a service station. i don't recommend trying to replace without knowledge of this. They are high powered and you can hurt yourself or damage the screen
issue 3: fluorescent bulb went bad
this is usually the least common but could have happened. usually happens when peopel spray their screen with cleaner and it drips down inside the bottom. This can be fixed by a service center but coudl get costly. best bet is buy a new screen.
