Logitech Wireless Access Duo Optical Desktop Keyboard/Mouse KBWIREOPT Logo
Posted on Jul 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cordless access duo, mouse won't work
Cordless access duo, keyboard works but mouse won't work
Roshan Rijal
Level 2:
Sergeant:
  • Expert 361 Answers
  • Posted on Jul 11, 2009
Roshan Rijal
Expert
Level 2:
Sergeant:
Answers
361
Questions
Helped
158828
Points
942
Please go on control and look mouse setting and correct it. and also look battery of mouse, if not work there is hardwere fault. (nepal)
  • Roshan Rijal
    Roshan Rijal Jul 11, 2009
    please go on control and look mouse setting and correct it. and also look battery of mouse, if not work there is hardwere fault. (nepal)
  • Roshan Rijal
Anonymous
Level 2:
  • Expert 118 Answers
  • Posted on Jul 17, 2009
Anonymous
Expert
Level 2:
Answers
118
Questions
0
Helped
65754
Points
157
Try connecting the mouse before the keyboard. one second on the receiver and release then one second on the mouse and release. always receiver first. if the mouse does not connect ater three tries and the keyboard connects right away mouse is dead. contact logitech.
How to connect cordless mouse and cordless key board cordless desk top EX 1oo to desk top computer
Make sure you have fresh batteries in the mouse and keyboard:
Plug your transmitter unit into an USB port,push the connect button on the TX, then push in on the connect button on the mouse and the keyboard. Also, install the cd that came with the KB/Mouse, to gain access to the features.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holy days!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
1helpful
Dear Sir I upgarde the os from Win Xp to Win 7. My
download driver from "http://www.logitech.com/en-in/433/154?WT.z_sp=Image&osid=13&bit=32"
also there is trouble shooting there which I highlighted
you must comment
My cordless mouse stopped working - no pointer on screen - do i need a battery or something
the batteries dont last very long,a month in some mouses check that the transmitter is working which runs the mouse
2helpful
Logitech Ex110 keeps losing connection
Ok wht you need is batteries (preferably rechargable save the earth etc) There is a slot on the back of the keyboard where i think 2 or 3 batteries can be placed in the keyboard take a gander and tell me what ya got.
I have a Logitech cordless mouse/keyboard I bought for work and took home with me upon retiring. I am trying to install it on my home computer, which is older than my work computer. I did not retain the...
Un plug your mouse plug from your computer. next push the buton on your remote control, And push the mouse buton then the keyboard. it will work. if it does not work push the keyboard first then the mouse. it works for me . hope it does for you. ty saw
1helpful
Can't get cordless mouse and keyboard both working. Can only connect one or the other.
disconnect the small wireless dongle from the back of your computer..reboot the computer..put it back in,,and then press the connect button on bothe mouse and the keyboard to check,,the battery of teh mouse and the keyboard shud be checked if possible
1helpful
Hotkey problems
I had the same problem but finally found a solution hidden in the depths of Logitech. It's quoted below. I had to do it a couple of times before it worked, and it seems that you need to reconnect the mouse at the same time. I didn't the first time and then the keyboard refused to work. (Finger trouble?) :-(
Cheers,
Magani
The following is from :-
http://logitech-en-ap.custhelp.com/cgi-bin/logitech_en_ap.cfg/php/enduser/std_adp.php?p_faqid=28&p_created=1083786523&p_sid=hwmEUpij&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTkwLDE5MCZwX3Byb2RzPTg0NCZwX2NhdHM9JnBfcHY9MS44NDQmcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1teCBkdW8gaXRvdWNo&p_li=&p_topview=1
This article applies to the following products:
Cordless Access Duo
Cordless Acess Duo Optical
Cordless access keyboard
Cordless Elite Duo
Cordless MX Duo
Cordless Navigator Duo
You may be able to reset the keyboard and resolve the problem by clearing the keyboard capacitors. To do this, remove the batteries from the keyboard and type continuously on as many keys as possible for one to two minutes. This action should simulate touch-typing; you should not press and hold only some keys down.
After you clear the capacitors, replace the batteries and synchronize the keyboard using the following procedure:
  1. Make sure the batteries are in correctly. A diagram on the device itself or in the Getting Started Guide should tell you the correct polarity for the batteries.
  2. Press the connect button on the receiver.
  3. Press the connect button on the bottom or right hand edge of the keyboard.
    NOTE: If you are using a Cordless Desktop System, you must do this procedure for both the mouse and the keyboard.
The "Connect" button on the mouse is quite small and usually requires a pencil tip or other small object to push it. Remember, ALL Logitech cordless devices will have a synchronization button. If you have the "Cordless Mouse" with Model Number (M/N) M-RN67, the button will be located in a small hole on the lower portion of the back of the mouse. You will need a paper clip to access the button.
2helpful
Logitech cordless mouse and keyboard installation
You probably already done this but try pressing the receiver button and while it is flashing turn the board over and press the small reset/connect button on the bottom of the board and also the reset/connect button on the bottom of the mouse. It should work okay after that. here is hoping that helps. Bud
Top Logitech Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
