SOURCE: DVI to VGA connection problem
hi there,
well have you try to restart the laptop first..? -or- did you have test it first..?
`jack
SOURCE: Connecting my laptop to my new TV
To convert VGA format to HDMI format you need a piece of hardware, check this WEB site.
http://www2.dvigear.com/convert-scaler-video-pc-hdmi.html
SOURCE: connect my Dell Vostro 1400 laptop to my HDTV via VGA
If the Vostro doesn't read the signal automatically try to switch the signal from internal to external using the Fn (function) key + one of the F keys above the number keys. This key is usually F4 but may be different for yours. Also, make sure the input is correct on the tv....
SOURCE: Laptop to TV Connection
Check if you are sending the signal to the external monitor. On my laptop with Windows 7, I can right click on an open section of the desktop and choose Graphics Properties. In this window, I can choose to send the display to the laptop's internal monitor, the external monitor or both.
Pressing Crtl-Alt-F1 will force the video onto the external monitor on the fly (Crtl-Alt-F3 goes back to the laptop's screen).
When I have added a second monitor to a desktop, I needed to reboot and allow new hardware to be found before the related Screen Resolution (right click on the desktop again) let me find the second monitor and choose if this was a duplicate or extended screen.
I hope this helps.
SOURCE: I have a tosihba a205
on your laptop locate the FN button and then on your key someplace there is a picture with a light screen and dark screen on it hold FN and hit that button it alternates the video feed from your monitor to the tv, then to shut it off hold FN and hit it again to switch to the monitor
