20 Most Recent ASUS M4A785M Motherboard AMD Phenom X4 9850 Quad Core Processor Black EditionOEM Bundle (M4A785M WHD9850XAJ4BGH) Questions & Answers
i am not sure what you mean
but if you cant get an internet connection
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question / exclamation mark ? ! or a red X right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledimake sure its enabledPci device arrows key scroll to nstalled.
hope this helps
ASUS M4A785M... | Answered on Sep 14, 2012
old plasma? what is full model name of TV?
i guess wifi fails on TV.
so is TV close to the router wrong at or 100ft away.
do all other things work on this router wifi
cell phones (standing near TV (distance matters)
or any laptops
or notebooks or pads?
test that first. if that fails the router is set up wrong
is it your router or the ISPs?
learn to diagnose WIFI , hint try more devices
on my verizon cell phone, it has wifi option
i turn off 4g saves money doing that)
an then turn on wifi (home wifi) and set that up
if that works the router is ok
if still only TV fails. the TV may be too old, no tv model told
so if TV is very old, and does not do WPA2
and your router is set to WPA2 only (like mine is now)
then it can fail at the TV only.
here in your router do this, just 3 steps.
set the SSID first,, to like rover123 (a name you now, instantaly as yours)
easy no?
next set the encrytpion to what you TV can do
if TV is WPA1 only set router to, wpa1 /2 both. dual wpa mode.
do not use WEP it is not safe.
now set you Pass-phrase (pw)
to say this,. (not this , this its lastpass created do your own)
do not use dictionary PW.
now it works, at home. just 1 example, then write it down.!!!
8vngIaUVaQTx
OR DO THIS:
connect the router with cat/5/6 cable to the TV Ethernet port assuming it has one. and bam fast easy connections
in TV you must tell it to use what ever you have now.
first. in INTERNET connects inside TV menus. smart screens.
ASUS Computers &... | Answered Yesterday
tpu? tell exactly where you think the non fuse is>/?
teleportation unit? LOL?
show photo, only those can work doing FINE work like this.
a mobo is what you have in hand right?
there is no fuse there, (it's in the PSU if at all. )
are you confused on crystals (CR1 to5,etc) those are not fuses547a966d-7ee9-45c6-a686-67990836dc1d.jpg
ASUS Computers &... | Answered 3 days ago
fresh posts. read the spec on the tab. it tells you what is inside the device.. 802 wireless is wifi the 4g hardware varies by country, unstated by you. by communications laws in every country here USA is FCC laws. and by CARRIER, no carrier stated either,. your model number is malformed, incomplete. 100s of submodels made, only full models can we find a spec. is this a zenpad? S3 (not 3) but S3? you left off the S? 9.7" screen ok. ever look here, and find your TAB. if you find it there, and read the spec and has 4G then call your carrier ask them if they support this tab the carrier may only support a tiny few tabs so ask them first. https://www.asus.com/us/Tablets/
ASUS Computers &... | Answered on Dec 10, 2018
Ecommerce is an all-encompassing term referring to the buying and selling of services/goods/items on the Internet. Popular ecommerce sites include Amazon, ebay, J.C. Penney, Overstock, etc. It has evolved along the years with the innovations in web designing and development. A regular user can make an e-commerce site using tools provided by shopify, magento, wordpress and many more.
For more information about ecommerce, visit http://www.izzonet.com
hello Kai, welcome
the PC is an ASUS, one of the best brands for sure.
the drivers are at Asus.com from 1995 to now, every day, there.
all you do is go there , click your PC there
and see all drivers for every OS they support.
you said w10, so lets see what it there,
2nd google hit.
asus n76v laptop.
https://www.asus.com/us/Laptops/N76VZ/
easy no>
then i click top right support
and then click drivers
we see no w10 drivers, so there are non for this model.
why not tell the helper which driver fail first.?
DEVICE manager errors or a device is dead?
are you internet connected? on that PC?, do so.
do you know how to force load w8 drives.
the trick is simple
download those drivers that are dead, now.
lets say. wifi is dead (the hard nut)
first connect a CAT5/6 standard ethernate cable from your router
ports to the PC 8 pin Lan port.
bingo you have internet.
then let plug and play work right for the first time.
if that works and wifi driver wakes up end story
if not force load the W8 wifi driver above.
Version V10.0.0.2632013/10/1239.42 MBytesQualcomm Atheros Wireless Lan Driver and Application
down load this.
then unzip the fail to a folder called wifi or what seems nice
then see lots of fails
then see setup.exe
the right click the exe, and pick properties, then tab compat.
and set compatiblitiy mode to w8
and then run the exe and it force loads, w8 into w10
there is no guarantee this works,
if it fails ask how to find a drive, that Asus does not support
nor MS. PnP servers.
we can do that, but you need to tell me the what is failing
first, then pick one to fix first.
we can do it 1 by 1 and never all at once in this silly text box.
you upgraded with out ASUS permission, that is what you did .
in fact most PCs do not run w10 (old ones)
if chip never had w10 drivers ever, that is a problem.
https://www.asus.com/us/Laptops/N76VZ/HelpDesk_Download/
ASUS Computers &... | Answered on Dec 08, 2018
Possibly but your question lacks information. You can use the Comment menu to add details to your question. If you don't have the BIOS password, that will be difficult to resolve. If you don't have the Windows password, there are several methods to completely erase the hard drive and install Windows or other programs. You don't state what version of Windows is on it, but most likely an older version of Windows based on the age of that model laptop.
https://www.cocosenor.com/articles/computer/reset-bios-password-on-asus-laptop-desktop-computer.html
https://www.cocosenor.com/articles/computer/3-ways-to-unlock-asus-laptop-without-the-forgotten-password.html
OP I have no idea what PC you have?
for sure all things inside, PSU model full # (tag makers name and model #)
all cables connected, or failed to connect.?? AUX?
no PCI slot filled,? with what? Video card If yes what card?
We get it the HDD has windows and is no good
and you try to install windows, from unstated media,
we can not ever guess what media or if ISO from whom?
stop searching on google , otherS PC are not Your PC, ok?
learn to post facts full please.
or post photos of all you have there.
there is no other way to get help with everyone here blind in a text box. or googling, all helpers are blinded by lack of key facts.
first off its not new, but is new to you ,my guess bought used off fleabay for way too much cash, as we see endless now.
the 870 is the oldest I7 ever made, GEN 0 it 1870 is gen1 so
we are up to gen 9 now. so old old cpu it is but not a problem
for w7 (w10 is a problem ask)
G0 is ok, just slow, no issues. Intel built September 2009
as you can see it is 9 years old today. NOT NEW.
1: no install media stated.
2: PSU model not stated.
3: power cables to mobo (both) and to GPU card AUX not stated.
4: DDR3 memory partnumbers and maker not stated, matters.
DDR3 must be on Acers qualified memory list, is it? I cant look for you, unless told make and model ram.
My guess is wrong PSU, I cant see your PSU or inside your case but let me guess the MOBO 4 pin aux cable is MISSING.
and that will fail. just like you said.
the BIOS 1 page, set BIOS to defaults and exit save.
and if you did that the HDD0 will boot, if HDD is not defective.
I see you installed w7 but how far did you get, to the last step reboot? and then it fails ,first removing the w7 unstated media,
(dvd media) not removed the install loops endlessly.
the 2nd phase of the install , runs from HDD only.
and connected to the internet via Ethernet makes that way better. now. plug and play working better like that.
I never install any OS ever, unless I run the HDD tests called
SMART< I run that and if smart fails the HDD IS NO GOOD.
no HDD stated at all, new, or 10 years old, nothing.
Your motherboard, has 2 power feed connectors
24 and 4
I bet 4 pin is missing, cable. am I right,?
If only you';d spec out what is in the box (chassis) or one photo of inside, answers go 10x better, be like the first ever here to do that.
see this wire, here,
from PSU to the far right corner. behind the fan left rear edge
that is AUX if missing the PC crashes all the time or is dead.
if PSU is 1999 to 2008 expect bad caps, we dump these PSU .
http://pcdied.com/intel-magic/min-mobo4w1.jpg
/uploadswith image
ASUS Computers &... | Answered on Dec 03, 2018
Take a copy of your DBF before starting...
set environmental variable before launching.
SET TABLEVALIDATE=0
You may have to also set this in Foxpro (It's been a while since I used it so can't remember):
SET TABLEVALIDATE TO 0
Follwowing commands in Foxpro should fix the header record count.
USE corrupt.dbf (your DB name here obviously)
APPEND BLANK
DELETE
PACK
ASUS Computers &... | Answered on Nov 28, 2018
Google your model # and you should be able to find a picture
ASUS Computers &... | Answered on Nov 24, 2018
nice question,
but there is NO ANSWER TO that, LET ME EXPLAIN,
did you lose the original CPU?
first off only Asus.com knows this, ask them,
reasons is.?
1: the BIOS must be updated first, to use other CPU (fact)
2: after the update there is a new qualified, CPU list by ASUS.
3: the motherboard, electronics must like it too (bridge chips)
4: TPD rules (q8400 is 95watts)
now you know the rules 4.
so ask them, there are also MOBO version too, that can get in the way, v1, and v2 may not be the same ever.
page 1.
LGA775 socket for Intel® Core™2 Duo/Pentium D/Pentium 4/Celeron D
so why not read the asus support page first (1st google hit)
https://www.asus.com/Motherboards/P5SD2VM/HelpDesk_CPU/
says bios v510 up does. clear as day.
Are other devices able to connect to the same wireless network? restart the computer and the wifi and check if the computer is getting connected to the wifi. if not, go to the asus support page and download the latest asus wifi drivers and install
ASUS Computers &... | Answered on Nov 22, 2018
by waiting for it to load.
no PC stated at all, model and #
honestech is video editor only
why not ask maker of that app.
or read minimum requirement on that APP First.
not just guess.
page 6 says XP only.
ask the maker for w10 version, be super wise that.
RTM?
honestech 2.5 tvr (relic old app)
https://www.honestech.com/pdf/user%20guide_video%20to%20dvd%20converter%20suite_r12.pdf
all I have are questions.
did you upgrade your PC to10?
did you load Honestech from scratch now.(not your 2.5 , but V3?
https://www.honestech.com/main/SoftwareUpdates.asp
did you get the w8 version or after update, seems not.
did you attempt to load it in W10 (w8 ) compatibility mode.?
ask the maker yet, seems not. (we are not them we do not sell software or updates)
https://www.honestech.com/main/index.asp
ASUS Computers &... | Answered on Nov 21, 2018
so you are installing a ASus motherboard into and ACER?
that it?
I'm typing on Z270 prime right now,
its in the manual at asus.com
so this post is really ASUS, not ACER.
my guess is you forgot the B in B250M? right
if yes here is your manual
https://www.asus.com/us/Motherboards/PRIME-B250M-A/HelpDesk_Manual/
page 10 , pin manual ,bingo.
https://dlcdnets.asus.com/pub/ASUS/mb/LGA1151/Z170-K/E11133_MB_Pin_Definition_v2_web_only.pdf?_ga=2.138986227.1987888082.1542360124-596959811.1540214581
all manuals are there
ASUS Computers &... | Answered on Nov 18, 2018
http://www.wikihow.com/Remove-Mobogenie-Virus
ASUS Computers &... | Answered on Nov 13, 2018
windows 10?
post the model number of this player.
is the player connected to its power pack, plugged in?
try all USB ports? or is it using eSATA port, no port type stated.
USB, when plugged in does windows (is it windows) go BINGBONG
sound, telling you USB is not dead?
does it show up in device manager
does it show up in Disk manager?
last would be "This PC" local explorer working and see a disk there.
play what.
CD-DCA
Home burned, MP3 music on CD or DVD?
store bought DVD ,say starwars DVD real not a RIP.
always test with real CD/dVD first, not burned copies .
then last we check that DVD-R worrs or CD-r burned disks play.
what player are you using,? I use VLC , only.
ASUS Computers &... | Answered on Nov 12, 2018
ASUS M4A785M Motherboard  AMD Phenom X4 9850 Quad Core Processor Black EditionOEM Bundle (M4A785M WHD9850XAJ4BGH) Logo
1 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
amd phenom 9850 motherboard support fix
  • Computers & Internet
