Contributor
- Posted on May 20, 2015
Re: Compressor is just humming all the time, even when...
Need alot more info. Analog or digital thermostat? Does it do it when you command the thermostat or does compressor just start when you plug your unit in to power?
I have to agree with Johnny on this one. Air conditioners on RVs aren't the same as residential AC systems. If you take it to an RV repair service, they'll be able to they'll be able to find out where the humming is coming from. Not only that, but they'd probably be able to fix it as well. I'd definitely recommend getting it serviced. Good luck to you, James! http://www.orangewoodrv.com/pages/servic...
Battery 12 v? If it is thermostat, motherboard has fuse?, Motherboard shorted under black? Converter good ,,,? Good Luck
