Heating & Cooling Logo
Anonymous Posted on Oct 16, 2012
Air compressor on Heil air conditioner is humming but not kicking in
Air conditioner wont start just hums
MightyMikeJr
Level 3:
Master:
  • Master 409 Answers
  • Posted on Feb 27, 2015
MightyMikeJr
Master
Level 3:
Master:
Answers
409
Questions
0
Helped
313834
Points
1250
Capacitor Failure Symptoms are sometime harder to identify without the right tools and expertise. Capacitors can be found in several different sizes and shapes. There may be one or multiple capacitors included in your ac with regards to the design. While the most popular capacitors are the types found on circuit boards, the ones most associated with air conditioning will be the bigger capacitors that assist start and run your motors. There are several motors present in an conditioner and heater systems:
  1. Compressor Motor Run Capacitor: Here is the most popular capacitor that fails. Most of the time these are duel capacitors, which means that there are 2 capacitors built into one. A duel capacitor will have three terminals on the top where a single capacitor will simply have two terminals on top.
  2. Outside Fan Motor Run Capacitor: That is the smaller capacitor found with or part of the Compressor Motor Capacitor. It helps start and run the outside fan that blows air through the outside coils.
  3. Indoor Blower Motor Run Capacitor: Similar to the outdoor fan motor capacitor, it is a small, single (two terminals) capacitor that will help start and run the indoor blower motor.
  4. Start Capacitor: Some models include an auxiliary start capacitor that helps jump start the motors. Most are found on the compressor. These are less common.
You may need to get that checked out.
Air Conditioning
5 Related Answers
butch welch
  • 147 Answers
  • Posted on Sep 30, 2008
SOURCE: heat controller mini-split air conditioner
Check each screw on your compressor to ground (compressor case). Should be very high resistance Then check the resistance across your teminals on the compressor to be sure it is not shorted. Then check the wiring to your capacitor (The big one). I ran across this just last week. The mechanic didnt have the capicator wired correctly. If it is brand new it will have a wiring schematic somewhere on it.
Dont leave the compressor on very long, but turn it on long enough to get a voltage reading across the terminals. I assume it should be 240 volts. If you have check all of this, they make a jump start gadget to start a stuck compressor. They sell it just about everywhere. Let me know how this comes out..
Anonymous
  • 85 Answers
  • Posted on Dec 03, 2008
SOURCE: My new Amana compressor Central Air-Heat Pump hums very loudly
When it hums, is it running? Or does it not run when it hums? I'm assuming it runs when you say you have to turn the therm off to get the noise off.. If it's humming and not running, you have big problemo friend..
Rizwan Noori
  • 30 Answers
  • Posted on Feb 01, 2009
SOURCE: Window Air conditioner pulls too many amps
Probably Seems Replace Running Capacitor Located in Component Box or Nearby Compressor
Anonymous
  • 462 Answers
  • Posted on Mar 28, 2009
SOURCE: CARRIER MODEL 38YCA030370 MAKES HIGH PITCH ELECTRICAL HUMMING NOI
Yes it could be the pop off pressure relief on the compressor.
I assume it is the outdoor fan your referring to not running.
If this is a heat pump and it is in defrost (only in the heating mode should your outdoor fan be off and then for only a max of 12 to 15 minutes).
If it is just AC ir is Heat pump in cool mode, the out door fan should run while the compressor and indoor fan are on. Until the thermostat is satisfied on room temp.
This high pitched squealing is indicative of a bad fan motor or capacitor for the out door fan motor. Kill power and test blades to see if turns free. Check the run capacitor inside control panel. It is usually silver or aluminum colored (some are painted gray). The top should be flat with rolled edges and the sides should either be round or oval shaped with no swelling or oil leaking from inside it. If this all looks normal take it to where your going to get a motor any way and ask them to check it or sell you a replacement at the same time. These can go out usually from high voltage (lighting...) or from over heating (bad fan motor, dirty out door coil...).
Hope this helps you if not post back I'll respond as soon as I can. And please rate me as high as you can. Thank you for using Fix ya and good luck.
Anonymous
  • 3361 Answers
  • Posted on Apr 22, 2009
SOURCE: air conditioner hums then shuts off
Replace the start/run capacitor.
Amana air unit does not kick in, compressor hums
Hi Bowmunster,
Sounds like it could be a couple of things - the run capacitor could have failed or the compressor has seized - having said that a wire could have burnt off the compressor terminals
Good luck
My air conditioner will not start up. It makes a humming sound but does not kick in. I have a Kenmore window type air conditioner . It is model 253.70151. It was bought in 2012.
Sounds that compressor is locked,first check capacitor, if ok then you need a hard start kit for compressor,if still won't come on bad compressor
My heil n9mp2 isnt working just hums
is the flame igniting and then cutting off? on a gas furnace, the induction fan motor(draft motor) should start first (if the furnace is so equipped), then the flame, then the blower. if you have an induction motor (flue gas exhaust mmotor) this may be your problem (the induction motor isn't starting), if your unit doesn't have one, have you checked to see that you have gas? finally, the capacitor on the blower motor may be causing the motor not to start.
UNIT IS NOT FUNCTIONING.
See if you can hear the compressor start, if that does not start and your fan hums, it is most likely your dual capacitor. If compressor starts and fan hums, it is most likely your fan.
I have my dometic Rooftop ac unit. The heatstrip/fan run perfectly but when I turn on the ac...the fan runs good but when the compressor kicks on it just hums.
The compressor coming on does make a slight "humming" sound which is normal. Is the unit cooling properly? Do you think it is louder than before?
Coleman rooftop a/c hums in all modes, does not start
Replace the start capacitor for the fan and compressor. Check all the wires to the capacitor.
A/c compressor hums
The compressor may be fine after setting off or a day. After retyring it then if it still dosnt start either replace the run capacitor to the compressor and fan motor or have it checked to see if it is in range.
The hum your hearing could that be the contactor relay humming?
A/C runs but Compressor Does not Kick-In
Sounds to me like the contacts that are humming. Check your fuses or breaker.
Top Heating & Cooling Experts
Paul Carew
john h
