Hoover hav 340. stopped working. no idea what to look at
I have a hoover hav 340. A few days ago I noticed that the refrigerator was not really cooling and the motor kept going on 24 hours a day. Yesterday stopped working at all. The engine seems to work (well, it makes an almost normal noise) the light works, but inside it doesn't get cold at all. Any idea on what the problem is? I really don't know where to start from.
hi, I did what you suggest. however the freezer was not cold, and I had to get rid of the food. the refrigerator is clean. no water. the unit has been unplugged for over 24 hours, but when I pluged it back did not work. no cold at all. I'd like to know what could be the cause of the problem: motor, or other electrical/electronic stuff?hi,
You can't post conmments that contain an email address.
Re: hoover hav 340. stopped working. no idea what to look...
HEY JOE : TRY THIS
TAKE FOOD OUT CLEAN WELL.
IF THE FREZZER IS STILL COLD .
UN PLUG YOUR UNIT FOR 24 HR .
DRY UP ALL WATER .IT MAY START WORKING WHEN ITS PLUGED BACK IN.
The Hoover Company
Rating: 3.5 - 84 reviews
Dual Power™ Carpet Cleaner. Easy to Empty Tank ... You currently don't haveany recently viewed items. ... 3.5 out of 5 stars. ... The Hoover Dual Power™ Carpet Washer deep cleans on the double. ... 1 Year Limited Warranty .... The rinsing stage is a must and it cleaned a 20 year old carpet that was badly stained.
? 1:19
https://www.youtube.com/watch?v=6TkcWjuz1zw
Aug 16, 2013 - Uploaded by Hoover
Your SteamVac carpet cleaner should pick up as well today as the day you got it. If you're experiencing loss of suction or noticing that your SteamVac won't . ... Hoover 1 year ago ... thank you! worked and i did not have to wait for call center to open! thank ...This machine is running well almost four years in.
I have a Hoover f7412900 carpet cleaner and one day the brushes stopped working. ...It was a couple years ago, so I don't quite remember, but it was in the manual, ... Itwon't start back up. ... If it is only 5 months old, it is likely still on warranty. ... Do not try to fix this yourself, as you may void the warranty if you start taking ...
Honestly, most people are not experienced on LG to know all the symptom and their solution. I guess you will have to wait for it to break again to have it fixed.
If you live in a humid area, I'll bet ice buildup is screwing with the air flow. I have a similar, but less intense problem. So in my case, simply unplugging the fridge and letting all the hidden internal ice melt solves it for several months. GE sells a "moisture kit" which I refuse to buy, since it's $340! Plus, I doubt it will fix anything. Good luck!
i suspect the fan is not working. take the back panel off inside the freezer and check that the fan is free to rotate, check for continuity thro the fan motor and check you have power to the fan
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
hi,
hi,
