I got a jamed trunk lock open after being rearended with a cheep fast food flexible plastic knife it may help. Once open will you replace said handle? or complete door from auto recycler? If so you could probably drill out the locking mechanism but may destroy the door you may replace anyway. Good luck
Gently. With a screwdriver.
SOURCE: How do I get to the heater filter on my 2009 kia carens
I eventually found the answer to my problem on a website called kia-forums.com telling me to open the glove box and pull it sharply and backwards.it disconnects from the plastic hinges. The filters are easy to replace by unclipping the cover which is easy to see. This is for a 2004 kia carens
SOURCE: 2000 KIA sportage 140,000+ miles. Fix it or Donate?
I had same dilemma with my car I knew I wouldn't get much for it I checked online to donate it. You get a $500 dollar tax write off which is worth it because I tried to sell it and only got $300 for it.
Just type in donating car
SOURCE: Timing belt broke on my kia sportage...
Check solutions for Kia Sportage under heading. Need timing marks and ignition wiring by Brattlehead. The markings I gave him will also work for your 2001 Sportage
SOURCE: ac leak under glove box Kia sportage
remove it for repair, its better to change a new evaporator core
