Garden Logo
Posted on Apr 07, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There,s no power coming in from the mains ,whwt is the problem plx.
Bill Boyd
Level 3:
Top Expert:
  • Karcher Master 53,816 Answers
  • Posted on Jul 05, 2015
Bill Boyd
Karcher Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11951414
Points
172802
Check mains fuse in power board
I have a 2008 cadillac srx 6 cyl. check engine light has been on, had auto zone to put it on computer, they suggested loose or misaligned dual camshaft on drivers side, wat do youy think
use an OBD2 scanner to reset it. most auto parts stores will either have one to buy or they will use it at their store to do it for you with their scanner. so you can prepare one for yourself. make sure that you have the problem(s) fixed or the light WILL come back on.
How to remove check engine displyed from my car
You cannot remove the check engine light or malfunction indicator light ..you must bring to a nearest auto shop to scan the fault..if u dont have scanner you try to disconnect the negative side at least 20 second to elimanate na check engine but if the lights comes on its means there are problems in the engine....
How to connect the planronics plx500 to the phone? what is the use of each one of the bottoms?
Unfortunately finding life on another planet would be easier than locating an ancient (electronic years) PLX-500 user guide. However, I happen to have one of those ancient writings (no, it wasn't in a cave at the Dead Sea), albeit a bit tattered and yellow, so I'll try and give you a rundown of it's various features.
The top buttons for headset/handset and mute, and listening volume wheel are pretty self-explanatory. Now let's talk about connecting the PLX-500 to your phone and the other amplifier features.
1) Disconnect the telephone handset cord from telephone base and insert the PLX-500 modular plug into the handset jack on the phone. You then insert the coiled handset cord into the back of the PLX-500 base (there's only one place it can go into).
2) Plug the cord from the headset into the jack in the front of the PLX-500.
3) On the back of the PLX-500 base there are two switches (1-2 and 3-4). These are used to configure your PLX-500 to your phone (most electronic single and multi-line phones, such as Panasonic, will use setting 1 and 4). You will have to configure the PLX-500 to your specific phone. Having connected your PLX-500 to your phone, put on your headset, press the headset button on the base, lift the handset of the phone cradle and listen for a dial tone. Adjust the switch settings until you hear the best dial tone.
4) Remember that your PLX-500 uses batteries located under a cover on the bottom of the base (some phones will work without your PLX-500 needing batteries, check configuration before installing batteries). Speaking of the cover, there is a small plastic screwdriver attached to it that you use for adjusting the volume of your microphone. That adjustment is located on the back of the PLX-500 base next to the configuration switches.
Hopefully this gets your PLX-500 up and running.
Good luck from Headsets Direct!
Loose of power at low revs
idle control valve, intake manifold leaks, other vacuum leaks, fuel pressure regulator fuel filter.
Logic soundlab plx 46 red led lit in center of board what does it mean?
does it have sound if not it may be on a protect or themal mode try taking our=t your main fuse when the system is in and put it back in
11helpful
What do i do with a po603 code. i know whwt it means but now what?
If the Keep Alive Power (KAPWR) has been interrupted by a dead or disconnected battery, code P0603 may set on the first power-up. If this is the case, simply erase the code and see if it comes back.
If this is not the case, then the circuit between the battery and the KPWR terminal on the PCM must be inspected for an open. This circuit is hot all the times even with everything shut off.
If you need more specific info like fuse location, wire color, terminal number, etc. I would need to know what engine you have.
PLX help
Sounds like it could be overheating. I would take it back to where you bought it and ask for it to be booked in for repair. Not a software problem at all. Hope this helps :o)
Missing manual
go here:
http://www.qscaudio.com/products/amps/plx/plx.htm
right hand side of the screen....
documents...
plx users manual...
download...
enjoy !
Remember to rate the answer !!!...
thanks
Rob
Car audio
Product Details and Features PLX-520
Key Features
Amplifier Type grayquestion.gif Dual Channel Bridgable grayquestion.gif Bridgable RMS Power at 2 Ohms 400 W x 2
Performance
Frequency Response 10 Hz - 50000 Hz Signal to Noise Ratio grayquestion.gif 102 dB THD at Rated RMS Power 0.01 %
Crossover / Equalizer
Bass Boost grayquestion.gif With Bass Boost Low - Pass Frequency 50 Hz - 120 Hz High - Pass Frequency 80 Hz - 800 Hz
Other Features
MOSFET Circuitry Yes 3 Way Ready Yes
Dimensions
Width 10.4 in. Depth 17.7 in. Height 2 in. ..This is what I found for logic soundlab PLX-520 Amplifier, hope its what you were looking for. Don't forget to rate answers.
Top Karcher Garden Experts
Sean Wright
Sean Wright
Sulejman Sulejmani
Sulejman Sulejmani
ZJ Limited
ZJ Limited
Are you a Karcher Garden Expert? Answer questions, earn points and help others
