I'not sure what you mean short out components with aluminum strip? How would I do that?
First steps (you may have done done) check all wiring connections ,transducer, power,ext. at both ends. Attempt power up again. No change. Call 1-800-633-1468 with model & serial #'s. OR Disconnect all cable connections from unit and with a strip of aluminum foil short out all the connections on the 898c.(not the cable). Attempt power up again. If unit will let you go to 'System Status' screen & record. Hope your unit works.
