20 Most Recent
Humminbird Fishfinder 525 406260 1 Questions & Answers
I want to see the schematic diagram of humminbird
Hi Greg and Ernesto:
Re-stating the obvious, your transducer is not working but you know that the sounder is.
I would start by checking to see if your transducer works on a different sounder. That's just a double check to confirm that it really is not working.
Then I'd try to isolate the problem:
- Plug (couold be corroded or damaged)
- wire (could be broken)
- Transducer (could be defective)
Since these are sealed units, I'd be checking with the supplier to try to find a replacement. Hopefully they are not too expensive, and time spent fishing is better than trying to maybe save a few dollars, especially if you're taking out charters.
Best of luck.
THE UNIT WILL POWER UP
Hello
Just reset the unit to its factory settings first and see whether it helps you. To get it to its factory reset:
1# Highlight Restore Defaults on the Setup menu
2# Use the RIGHT 4-Way Cursor Control key to initiate restoring defaults.
3# The Confirm dialog box will appear. To reset the defaults, press the RIGHT
Cursor key once more. To cancel Restore Defaults, press the LEFT Cursor key.
Before doing this rest option make sure that the battery voltage at the power connector is at least 10 Volts with device on load. Correct any known problems incuding removing corrosion from the battery terminals or wiring , or actually replacing the battery if necessary. Anyway, the voltage at the supply terminal to the device should be more han or equal to 10VDC, at device in ON condition. OK.
Cannot get it to show fish
hit the menu button, then display options. The display settings is usually where the fish display is shown.
Humminbird 525 fishfinder, battery is fine, unit
Hi!
Sorry to say it sounds like you will need to replace the screen assembly which is about a $70 repair or so.
This is best left to a qualified Humminbird technician who has access to parts and support.
here are the numbers:
Where to ship your items:(if you live in the U.S.)
Humminbird
Attn: Service Dept.
678 Humminbird Lane
Eufaula, AL 36027
Who to call:
Toll-free: 1-800-633-1468
Monday - Friday
8:00am - 4:30pm CST
Authorized Service Centers - Canada
Bay Distributors
119 Progress Ct.
P O Box 70
North Bay, Ontario, Canada P1B 8G8
Tel: (705) 476-6010
Email:
[email protected]
Mike's Reel Repair
#108-31060 Peardonville Rd
Abbotsford, BC V2T 6K5
Tel: (604)855-1119
Email:
[email protected]
www.mikesreelrepair.com
PTG Electronics Ltd.
3092 Portage Ave
Winnipeg, MB R3K 0Y2
Tel: (204)831-0862
Fax: (204-888-6207
Email:
[email protected]
Humminbird 215 max fish finder- Replaced batteries and now won't turn on, the batteries are good and connections are good.
Brand: DIVTEK New water bicycle - Pretty Fast. Sport Fun, Take a Deep Breath. Cool Inflatable Water Bike.Significant TIPS : Please check the FREE conveyance time prior to purchasing our water bicycles. After you consent to the transportation time, then, at that point you can submit a request. We don't acknowledge discounts on the way, Hope you can comprehend. much thanks Bike boat Up. Our Water Bikes Bike boat. A elite water bike - customary bike position. Lightweight, simple to utilize, flexibility and clean. Appropriate for: Aquatic Parks, Aqua Lakes, Rivers and ocean, and Good thought for Local Water Bikes Rental Business HIGH QUALITY: The water bicycle is made of 6061 aluminum combination outline with heating. The outside is compact and lovely. The pedal and seat both have a dependable quality. Elite: The heading control framework without paddling capacities is steady, solid and simple to keep up. The transmission framework made of a high-strength coordinated belt is both waterproof and rustproof. The buoys are physically produced using 1000D 0.9mm polyurethane covering. Your floor is furnished with light and safe scoring strips. follow the linkhttps://waterbaike.blogspot.com/2021/06/with-water-divtek-water-bikes.html
